Profile settings gone in 1.87?
Cheddar
Where you would select FLAC or WDTV, and there was another one but I forgot the name of it.
dannyboy48888
Re: Profile settings gone in 1.87?
Ensure expert is enabled and what OS?
Cheddar
I know I should use FLAC for blu ray but what is the default setting? I am using windows 7.dannyboy48888 wrote:Ensure expert is enabled and what OS?
Which option you chose from the provided profiles depends upon what you're looking to do. Have a Western Digital LIVE player that you want to be able to read PGS subtitles? Select the WDTV profile. Using an advanced audio option that your player doesn't support? FLAC profile will reencode the lossless audio track.
Need both? Ah, time to get out a text editor, and create a custom profile....
But yes, you will need to enable Expert mode to see the selection box.
