Hash check failed for file /BDMV/STREAM/00001.m2ts at offset 2407655424, file is corrupt.
Too many hash check errors in file /BDMV/STREAM/00001.m2ts.
I've been recieving this error on every bluray i've tried tonight
No issues with dvd's though..
						Hash check errors?
Re: Hash check errors?
ah ha.. correction.. now i can't seem to rip any dvd's.. i think the drive is on it's way out.
DVD 's don't provide hash files! Also, Yes, seems like your drive has died.
Yes, it did.
Just came home with a new drive and its working fine now.
				PMJohnson9
I have been getting this error message quite a bit recently as well, although my backups appear to finish fine so I have not really been worried.  What else could be causing this message besides the possibility of a dead/dying drive?
BTW, although I know it doesn't really matter, my drive is only about 6 months old, so I hope it is not actually dying!
PMJ
PMJ
- Contact:
A bug in MakeMKV - you will get 100% hashcheck errors on certain (newer) drive-disc combinations. Will be obviously fixed in the next version. So you should either get a zero or 100% - anything else really means an error.PMJohnson9 wrote:I have been getting this error message quite a bit recently as well, although my backups appear to finish fine so I have not really been worried. What else could be causing this message besides the possibility of a dead/dying drive?
