Unusual issue ripping from image.
Nezil
Post by Nezil »
I have several computers networked in my home, but only 2 with BD-ROM drives. Occasionally I may back up to image (using AnyDVD-HD) and then use the backed up ISO with MakeMKV on another machine which doesn't have the BD-ROM drive. My computers are a mix of Windows / Mac & a Linux based NAS.
This approach usually doesn't give me any problems, but I have run into one today, and it's quite a curious issue.
If I rip from the original disc or the created ISO on my Windows machine (ISO can be located anywhere on the network, it doesn't need to be local), MakeMKV rips perfectly, with no errors.
If however I rip from the ISO image on my Mac (again, doesn't matter where the ISO image is located), MakeMKV detects numerous sync errors that it then tries to correct; these are simply not there on when I'm using MakeMKV on the Windows machine.
I've tried creating the back up image several times, and repeated the MakeMKV rips on the same ISO image several times with completely repeatable results.
The only difference that I can tell between the Mac and PC (besides the obvious), is that I'm using the latest Mac version of MakeMKV (v1.8.7), whereas I'm still using the slightly older (v.1.8.6) version on the PC.
See below for a log of the AV Sync issues on Mac v1.8.7 MakeMKV:
Saving 1 titles into directory /Volumes/Macintosh HD 2/Users/neil/Movies/Iron_Man_2_Disc_1 using profile '2D Blu-ray Backup' from file '/Volumes/Macintosh HD 2/Users/neil/.MakeMKV/2D_Blu-ray.mmcp.xml'
AV synchronization issues were found in file '/Volumes/Macintosh HD 2/Users/neil/Movies/Iron_Man_2_Disc_1/Iron_Man_2_Disc_1_t01.mkv' (title #2)
AV sync issue in stream 1 at 0:03:08.688 with duration of 4.291ms : encountered overlapping frame, audio skew is +4.833ms
AV sync issue in stream 2,3 at 0:03:08.688 with duration of 14.958ms : encountered overlapping frame, audio skew is +15.5ms
AV sync issue in stream 1 at 0:05:39.047 with duration of 9.458ms : encountered overlapping frame, audio skew is +14.291ms
AV sync issue in stream 1 at 0:05:39.061 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.625ms
AV sync issue in stream 2,3 at 0:05:39.047 with duration of 9.458ms : encountered overlapping frame, audio skew is +24.958ms
AV sync issue in stream 1 at 0:06:05.031 with duration of 10.375ms : encountered overlapping frame, audio skew is +14ms
AV sync issue in stream 1 at 0:06:05.045 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.333ms
AV sync issue in stream 2,3 at 0:06:05.031 with duration of 31.708ms : encountered overlapping frame, audio skew is +56.666ms
AV sync issue in stream 2,3 at 0:06:05.088 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +24.666ms
AV sync issue in stream 1 at 0:15:44.818 with duration of 9.791ms : encountered overlapping frame, audio skew is +13.125ms
AV sync issue in stream 1 at 0:15:44.832 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.458ms
AV sync issue in stream 2,3 at 0:15:44.818 with duration of 20.458ms : encountered overlapping frame, audio skew is +45.125ms
AV sync issue in stream 2,3 at 0:15:44.864 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +13.125ms
AV sync issue in stream 1 at 0:16:18.852 with duration of 3.333ms : encountered overlapping frame, audio skew is +5.791ms
AV sync issue in stream 2,3 at 0:16:18.852 with duration of 14ms : encountered overlapping frame, audio skew is +27.125ms
AV sync issue in stream 2,3 at 0:22:21.465 with duration of 11.75ms : encountered overlapping frame, audio skew is +38.875ms
AV sync issue in stream 2,3 at 0:22:21.504 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +6.875ms
AV sync issue in stream 1 at 0:22:21.465 with duration of 1.083ms : encountered overlapping frame, audio skew is +6.875ms
AV sync issue in stream 2,3 at 0:22:42.861 with duration of 11.625ms : encountered overlapping frame, audio skew is +18.5ms
AV sync issue in stream 1 at 0:22:42.861 with duration of 0.958ms : encountered overlapping frame, audio skew is +7.833ms
AV sync issue in stream 2,3 at 0:36:08.749 with duration of 31.583ms : encountered overlapping frame, audio skew is +50.083ms
AV sync issue in stream 2,3 at 0:36:08.800 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +18.083ms
AV sync issue in stream 1 at 0:36:08.749 with duration of 10.25ms : encountered overlapping frame, audio skew is +18.083ms
AV sync issue in stream 1 at 0:36:08.768 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +7.416ms
AV sync issue in stream 1 at 0:36:15.548 with duration of 6.875ms : encountered overlapping frame, audio skew is +14.291ms
AV sync issue in stream 1 at 0:36:15.562 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.625ms
AV sync issue in stream 2,3 at 0:36:15.548 with duration of 17.541ms : encountered overlapping frame, audio skew is +35.625ms
AV sync issue in stream 2,3 at 0:36:15.584 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +3.625ms
AV sync issue in stream 1,2,3 at 0:47:54.162 with duration of 9.416ms : encountered overlapping frame, audio skew is +13.041ms
AV sync issue in stream 1 at 0:47:54.176 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.375ms
AV sync issue in stream 1 at 0:48:21.440 with duration of 8.083ms : encountered overlapping frame, audio skew is +10.458ms
AV sync issue in stream 2,3 at 0:48:21.440 with duration of 18.75ms : encountered overlapping frame, audio skew is +31.791ms
AV sync issue in stream 1 at 0:58:53.780 with duration of 1.291ms : encountered overlapping frame, audio skew is +11.75ms
AV sync issue in stream 1 at 0:58:53.792 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.083ms
AV sync issue in stream 2,3 at 0:58:53.780 with duration of 11.958ms : encountered overlapping frame, audio skew is +43.75ms
AV sync issue in stream 2,3 at 0:58:53.824 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.75ms
AV sync issue in stream 1 at 0:59:09.629 with duration of 1.5ms : encountered overlapping frame, audio skew is +2.583ms
AV sync issue in stream 2,3 at 0:59:09.629 with duration of 22.833ms : encountered overlapping frame, audio skew is +34.583ms
AV sync issue in stream 2,3 at 0:59:09.664 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +2.583ms
AV sync issue in stream 1,2,3 at 1:10:44.698 with duration of 2.625ms : encountered overlapping frame, audio skew is +5.208ms
AV sync issue in stream 2,3 at 1:12:13.245 with duration of 29.208ms : encountered overlapping frame, audio skew is +34.416ms
AV sync issue in stream 2,3 at 1:12:13.280 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +2.416ms
AV sync issue in stream 1 at 1:12:13.245 with duration of 7.875ms : encountered overlapping frame, audio skew is +13.083ms
AV sync issue in stream 1 at 1:12:13.258 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.416ms
AV sync issue in stream 1 at 1:12:47.404 with duration of 6.208ms : encountered overlapping frame, audio skew is +8.625ms
AV sync issue in stream 2,3 at 1:12:47.404 with duration of 16.875ms : encountered overlapping frame, audio skew is +19.291ms
AV sync issue in stream 1 at 1:13:34.410 with duration of 2.708ms : encountered overlapping frame, audio skew is +11.333ms
AV sync issue in stream 1 at 1:13:34.421 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0.666ms
AV sync issue in stream 2,3 at 1:13:34.410 with duration of 2.708ms : encountered overlapping frame, audio skew is +22ms
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
AV sync issue in stream 1 at 1:24:13.381 with duration of 4.333ms : encountered overlapping frame, audio skew is +5ms
AV sync issue in stream 2,3 at 1:24:13.381 with duration of 4.333ms : encountered overlapping frame, audio skew is +26.333ms
AV sync issue in stream 1 at 1:25:03.348 with duration of 6.75ms : encountered overlapping frame, audio skew is +11.75ms
AV sync issue in stream 1 at 1:25:03.360 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.083ms
AV sync issue in stream 2,3 at 1:25:03.348 with duration of 17.416ms : encountered overlapping frame, audio skew is +43.75ms
AV sync issue in stream 2,3 at 1:25:03.392 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +11.75ms
AV sync issue in stream 2,3 at 1:33:36.027 with duration of 25.166ms : encountered overlapping frame, audio skew is +36.916ms
AV sync issue in stream 2,3 at 1:33:36.064 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +4.916ms
AV sync issue in stream 1 at 1:33:36.027 with duration of 3.833ms : encountered overlapping frame, audio skew is +4.916ms
AV sync issue in stream 1 at 1:34:35.878 with duration of 9.875ms : encountered overlapping frame, audio skew is +14.791ms
AV sync issue in stream 1 at 1:34:35.893 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.125ms
AV sync issue in stream 2,3 at 1:34:35.878 with duration of 20.541ms : encountered overlapping frame, audio skew is +25.458ms
AV sync issue in stream 1 at 1:35:10.413 with duration of 4.166ms : encountered overlapping frame, audio skew is +8.291ms
AV sync issue in stream 2,3 at 1:35:10.413 with duration of 25.5ms : encountered overlapping frame, audio skew is +50.958ms
AV sync issue in stream 2,3 at 1:35:10.464 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +18.958ms
AV sync issue in stream 1 at 1:35:26.429 with duration of 5.333ms : encountered overlapping frame, audio skew is +13.625ms
AV sync issue in stream 1 at 1:35:26.442 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +2.958ms
AV sync issue in stream 2,3 at 1:35:26.429 with duration of 16ms : encountered overlapping frame, audio skew is +34.958ms
AV sync issue in stream 2,3 at 1:35:26.464 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +2.958ms
AV sync issue in stream 1 at 1:47:17.931 with duration of 6.875ms : encountered overlapping frame, audio skew is +9.833ms
AV sync issue in stream 2,3 at 1:47:17.931 with duration of 17.541ms : encountered overlapping frame, audio skew is +20.5ms
AV sync issue in stream 1 at 1:47:37.409 with duration of 10.208ms : encountered overlapping frame, audio skew is +20.041ms
AV sync issue in stream 1 at 1:47:37.429 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +9.375ms
AV sync issue in stream 2,3 at 1:47:37.409 with duration of 10.208ms : encountered overlapping frame, audio skew is +30.708ms
AV sync issue in stream 1 at 1:49:22.806 with duration of 0.375ms : encountered overlapping frame, audio skew is +9.75ms
AV sync issue in stream 2,3 at 1:49:22.806 with duration of 11.041ms : encountered overlapping frame, audio skew is +41.75ms
AV sync issue in stream 2,3 at 1:49:22.848 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +9.75ms
AV sync issue in stream 1,2,3 at 1:49:35.277 with duration of 9.208ms : encountered overlapping frame, audio skew is +18.958ms
AV sync issue in stream 1 at 1:49:35.296 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +8.291ms
AV sync issue in stream 1 at 1:54:10.176 with duration of 1.708ms : encountered overlapping frame, audio skew is +10ms
AV sync issue in stream 2,3 at 1:54:10.176 with duration of 12.375ms : encountered overlapping frame, audio skew is +31.333ms
AV sync issue in stream 1 at 1:54:34.492 with duration of 4.041ms : encountered overlapping frame, audio skew is +14.041ms
AV sync issue in stream 1 at 1:54:34.506 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +3.375ms
AV sync issue in stream 2,3 at 1:54:34.492 with duration of 4.041ms : encountered overlapping frame, audio skew is +35.375ms
AV sync issue in stream 2,3 at 1:54:34.528 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +3.375ms
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
1 titles saved
Romansh
Re: Unusual issue ripping from image.
Post by Romansh »
The rip is successful ("1 title saved"). These are issues, not errors.
AV sync messages are not logged by default, you must have enabled it on the Mac but not on the Windows box.
Nezil
Post by Nezil »
You could very well be correct Romansh, I'm going to test and confirm this now.
Having said that... the AV sync messages are somewhat worrying. Why are they present at all? I certainly don't like the thought of having frames dropped in order to maintain sync; how would a standalone Blu-ray player do this during playback?
Edit: OK, confirmed that the log level was the reason that I wasn't seeing the AV sync messages on the Windows machine, and that the AV sync issues were in exactly the same place on both systems.
My question still remains however... Why should we be seeing AV sync issues at all?
If every disk were mastered "perfectly", there wouldn't be sync errors. But, they aren't.
Post by mike admin »
Starting with 1.8.7 MakeMKV always displays "important" AV issues; and displays everything if checked in preferences. Before 1.8.7 it only displayed everything or nothing. So if you have latest version, it is safe to disable "show AV sync issues" in preferences.
Romansh
Post by Romansh »
Nezil wrote:Having said that... the AV sync messages are somewhat worrying. Why are they present at all? I certainly don't like the thought of having frames dropped in order to maintain sync; how would a standalone Blu-ray player do this during playback?
It would:
- drop audio frames;
OR
- decode audio frames and drop some samples;
You'll find that kind of behavior on any and all BD titles that use seamless branching, AFAIK.
