The log I get is:
MakeMKV v1.8.4 linux(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
This application version is too old.  Please download the latest version at http://www.makemkv.com or enter a registration key to continue using the current version.
I suspect the program can't find the key, but is there a way that we can set it so it's not per user but instead point it to a key file located in something like /var?
Thanks in advance!
