Raspberry Pi Problem
suchalaugh
Post by suchalaugh »
Hi all and merry christmas:)
I just got a raspberry pi a few weeks ago to set up a media center with openelec.
So i started to put all my DVDs onto a HDD with makemkv 1.8.6 on a win7 pc.
The problem is, openelec doesn't play the video of any of the files i created with makemkv. I can hear the sound of a movie but no Video at all. All the other files are no problem at all. Example MediaInfo of a file created with makemkv attached;)
Does anyone has a raspberry pi and had the same issues? Anybody an Idea how to fix this?
Greetings from Austria:)
Allgemein
Unique ID : 161791598550869672530635525251764749590 (0x79B7EDAE3D69EBA0698879D7D3428516)
Complete name : Z:\Videos\Control.mkv
Format : Matroska
Format version : Version 2
File size : 4,25 GiB
Duration : 1h 56min
Overall bit rate mode : variabel
Overall bit rate : 5 204 Kbps
Movie name : Control
Encoded date : UTC 2013-10-27 20:52:32
Writing application : MakeMKV v1.8.5 win(x64-release)
Writing library : libmakemkv v1.8.5 (1.2.0/1.1.0) win(x64-release)
Video
Format : MPEG Video
Format profile : Main@Main
Format settings, BVOP : Nein
Format settings, Matrix : ausgew?hlt
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 1h 56min
Bit rate mode : variabel
Bit rate : 4 204 Kbps
Maximum bit rate : 7 900 Kbps
Width : 720 Pixel
Height : 576 Pixel
Display aspect ratio : 16:9
Frame rate mode : konstant
Frame rate : 25,000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : oberes Feld zuerst
Bits/(Pixel*Frame) : 0.405
Time code of first frame : 01:00:00:12
Time code source : Group of pictures header
Stream size : 3,43 GiB (81%)
Language : Englisch
Default : Nein
Forced : Nein
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B, BT.470 System G
Matrix coefficients : BT.601
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 56min
Bit rate mode : konstant
Bit rate : 448 Kbps
Channel(s) : 6 Kan?le
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48,0 KHz
Bit depth : 16 bits
Delay relative to video : -80ms
Stream size : 375 MiB (9%)
Title : 3/2+1
Language : Deutsch
Default : Ja
Forced : Nein
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1h 56min
Bit rate : 448 Kbps
Bit depth : 16 bits
Title : 3/2+1
Language : Englisch
Default : Nein
Forced : Nein
Text #1
Format : VobSub
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : Deutsch
Default : Ja
Forced : Nein
Text #2
Format : VobSub
Codec ID : S_VOBSUB
Language : Deutsch
Default : Nein
Forced : Nein
Text #3
Format : VobSub
Codec ID : S_VOBSUB
Language : Deutsch
Default : Nein
Forced : Nein
Men?
00:00:00.080 : :Chapter 01
00:00:49.320 : :Chapter 02
00:06:47.840 : :Chapter 03
00:12:31.280 : :Chapter 04
00:21:18.080 : :Chapter 05
00:28:47.480 : :Chapter 06
00:33:34.960 : :Chapter 07
00:41:14.720 : :Chapter 08
00:49:25.400 : :Chapter 09
00:59:14.920 : :Chapter 10
01:05:29.880 : :Chapter 11
01:14:20.200 : :Chapter 12
01:23:56.600 : :Chapter 13
01:29:38.400 : :Chapter 14
01:39:15.520 : :Chapter 15
01:51:01.960 : :Chapter 16
Chetwood
Re: Raspberry Pi Problem
Post by Chetwood »
Buy the mpeg2 license that's separately available in the raspberry store.
