The Lone Ranger - Multiple/Same Duration
seussiii
#1 Post by seussiii » Tue Dec 24, 2013 10:35 pm
I'm seeing 3 separate 37.0 gb titles (00800.mpls, 00801.mpls, 00802.mpls). Same chapter count and same duration (2:29:33)
Any ideas on how to figure out the correct one to rip or does anyone already know?
Lovely Rita
Re: The Lone Ranger - Multiple/Same Duration
#2 Post by Lovely Rita » Wed Dec 25, 2013 4:09 am
I do not have this disc, but in typical Disney fashion, one will have English credits, another French and another Spanish.
And the way I learned this was to rip all three for viewing to determine which one was correct.
My guess would be that 800 is the correct one but try my suggestion just for sh*ts and giggles.
Registered User :wink:
Buy MakeMKV
Chetwood
#3 Post by Chetwood » Wed Dec 25, 2013 6:39 am
No need to rip them first. Check the playlist number and play back the referenced m2ts.
shawnhaywood
#4 Post by shawnhaywood » Wed Dec 25, 2013 4:48 pm
Any chance you figured out which one is correct?
sweetwatermac
#5 Post by sweetwatermac » Fri Dec 27, 2013 4:21 pm
Chetwood wrote:No need to rip them first. Check the playlist number and play back the referenced m2ts.
Can you elaborate on what you posted? Not sure what you mean. Thanks!
Chetwood
#6 Post by Chetwood » Tue Dec 31, 2013 9:07 am
The probably easiest way to do it is to load the movie into DVDFab and select Copy > main movie. With Pathplayer enabled in the settings this will usually pick the right title for you. This title is the one you select in MakeMKV, you can verify this number in the right info pane, e.g. title 803 would show up as 000803.mpls.
awesomejdub
#7 Post by awesomejdub » Fri Jan 10, 2014 2:11 am
800 appears to be the correct title for English.
