DVD Read errors
MakOwner
DVD Read errors
Post by MakOwner » Sat Dec 21, 2013 11:47 pm
Kick-Ass (the original, not Kick-Ass 2) cannot be processed.
Running 1.8.6 (x64t) on Linux with the followin packages installed:
ii  libdvdcss2                                  1.2.13-0                               amd64        library designed for accessing DVDs
ii  libdvdnav-dev                               4.2.0+20130225-1ubuntu0.1              amd64        DVD navigation library (development)
ii  libdvdnav4:amd64                            4.2.0+20130225-1ubuntu0.1              amd64        DVD navigation library
ii  libdvdread-dev                              4.2.0+20121016-1ubuntu1.1              amd64        library for reading DVDs (development)
ii  libdvdread4                                 4.2.0+20121016-1ubuntu1.1              amd64        library for reading DVDs
Which reads other DVDs just fine. MakeMKV fails on two separate computers, with two different BD readers.
The DVD is brand new - I took it out of the shrinkwrap myself.
system logs record this on both systems (repeated many times):
[ 6227.118933] Add. Sense: L-EC uncorrectable error
[ 6227.118936] sr 2:0:0:0: [sr0] CDB:
[ 6227.118937] Read(10): 28 00 00 37 ae 10 00 00 01 00
[ 6227.118945] end_request: I/O error, dev sr0, sector 14596160
I'm sure this will get the "It's a disc error" response but this DVD plays fine in a DVD player and failes with MakeMKV on two separate systems.
Can anyone tell me how to rip this movie?
Re: DVD Read errors
Post by Woodstock » Sun Dec 22, 2013 3:36 am
Well, what does MakeMKV say about the disk? You've posted information about what Linux says, but not the MakeMKV debug information...
Just because a disk "plays" in a DVD or BD player does not mean it doesn't have flaws. DVD/BD players are programmed to skip over flaws, but ripping is trying to make a bit-for-bit copy (after decryption), so errors aren't ignored.
MakOwner
Re: DVD Read errors
Post by MakOwner » Sun Dec 22, 2013 3:22 pm
Woodstock wrote:Well, what does MakeMKV say about the disk? You've posted information about what Linux says, but not the MakeMKV debug information...
I'm doing another run to capture the debug log again.
This is the log from openeing the disk:
MakeMKV v1.8.5 linux(x64-release) started
Debug logging enabled, log will be saved as /home/dale/MakeMKV_log.txt
The new version 1.8.7 is available for download at http://www.makemkv.com/download
Cells 27-28 were skipped due to cell commands (structure protection?)
Cells 31-end were skipped due to cell commands (structure protection?)
Title #1 was added (25 cell(s), 1:57:26)
Title #2 was added (2 cell(s), 0:20:34)
Title #3 was added (2 cell(s), 0:02:29)
Title #4 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 was added (2 cell(s), 0:02:34)
Title #6 was added (2 cell(s), 0:02:34)
Title #7 was added (2 cell(s), 0:02:12)
Title #8 has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 was added (1 cell(s), 0:21:50)
DEBUG: Code 10551299 at OTHJq8~uNIzuC778:121270237
DEBUG: Code 0 at OTHJq8~uNIzuC778:121271410
DEBUG: Code 0 at ?m*D:Y5<v==~\FR,+F:213131042
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-9 were removed from title start
Cells 40-40 were removed from title end
Title #21 was added (30 cell(s), 2:07:05)
Debug from the rest of it to follow.
First failure - I believe this is the 24 chapter segment. The fisrt and last segments appear to the be the movie, as thay are about 4.8GB each - one has 24 chapters and the other has 25.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_16_1.VOB' at offset '19632128'
DEBUG: Code 0 at "Q~gk_x|-Asme=%`spMK:121262739
DEBUG: Code 0 at 71f'D6F`;?liwE}GYd/:121261681
DEBUG: Code 0 at "Q~gk_x|-Asme=%`spMK:213130743
DEBUG: Code 9586 at "Q~gk_x|-Asme=%`spMK:29393332
DEBUG: Code 0 at 7|rxt(1|C"Bgl)DmvAs.9:29398645
DEBUG: Code 0 at Cs)e,r7%RGSL;Z&+v*v:213132744
DEBUG: Code 0 at R`jV!5t. n)\?xfSE:121263728
DEBUG: Code 0 at R`jV!5t. n)\?xfSE:121263176
DEBUG: Code 0 at R`jV!5t. n)\?xfSE:29393930
Failed to save title 6 to file /home/dale/Videos/Kick-Ass/Kick-Ass_t06.mkv
Re: DVD Read errors
Post by Woodstock » Sun Dec 22, 2013 5:59 pm
Those indicate that the drive can't read parts of the disk. Usual causes are scratches, dirt, or a poorly-pressed disk. First step is cleaning the disk.
MakOwner
Re: DVD Read errors
Post by MakOwner » Sun Dec 22, 2013 8:43 pm
Complete log - linked here to prevent flooding the thread.
http://www.taftbbs.com/makemkv/makemkv.log.txt
MakOwner
Re: DVD Read errors
Post by MakOwner » Sun Dec 22, 2013 8:45 pm
I'd accept that as an answer, but this is a brand new, fresh out of the shrinkwrap disk.
And VLC plays it just fine from the same machine/drives.
crowfax
Re: DVD Read errors
Post by crowfax » Sun Dec 22, 2013 9:05 pm
playback isn't ripping, the fact you can watch them does not mean they are defect free.
MakOwner
Re: DVD Read errors
Post by MakOwner » Sun Dec 22, 2013 9:16 pm
crowfax wrote:playback isn't ripping, the fact you can watch them does not mean they are defect free.
OK, so let's assume the disk is bad.
How does one justify a replacement with a vendor when only one program fails to read it and nothing they have to test it with will fail?
crowfax
Re: DVD Read errors
Post by crowfax » Sun Dec 22, 2013 10:05 pm
"hi, I got this DVD and it won't read I one of my players, can I get a replacement please?"
