Unable to open any BD with 1.8.7 (fedora 19 with static ffmp
miracoolix
Post by miracoolix »
while beeing delayd for fedora 20 and an offical ffmpeg upgrade, i built 1.8.7 as described with static ffmpeg (2.1.1).
MakeMKV works, but I'm unable to open any BD now (even those that worked in the past). It worked with MakeMKV 1.8.5. Any ideas?
The output is always:
MakeMKV v1.8.7 linux(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00ACB8E1DE3002EB584FB1A9EFAA1940982 to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BE9A37BE3E172D6F3AFA7B96B6AC38AA2E to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..045D403B15632E27E286044583FFEFEC071 to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B119ED1DEF1394E753153E5BE23B29A367 to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D159DA4090CEDF9CCFF41FE322DC45CC47 to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0753BCC6EDDC51AFA4DF208EE707DAF01BE to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..094F70E77326EE0DA269CF927C26AB6AAB0 to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B8820C06B856F6F7C4EAF3D4BE83F1C232 to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CCF6762564B3B6082E7E11B39EE0E04F26 to device 'SG:dev_11:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A11918C8C00CCE7F3E2D5FF3EF3A05AB4F to device 'SG:dev_11:1'
Highest AACS version is v40 , MKB saved as /home/mike/.MakeMKV/MKB_v40_PLACE_BEYOND_PINES.tgz
miracoolix
Re: Unable to open any BD with 1.8.7 (fedora 19 with static
Sorry for not using the search.
That aacs key problem is already discussed here:
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=7300
tor123
Post by tor123 »
Can you post which linux kernel you are using. rpm -q kernel. I have the same problem and filled a bug at https://bugzilla.redhat.com/show_bug.cgi?id=1042715
tramal
Post by tramal »
Hi there!
I am using MakeMKV 1.8.7 on a Fedora 20 system. I have the exact same problem with any BR I try to open. Even those that worked before on 1.8.5. This problem started with version 1.8.6. I hoped it would be fixed in 1.8.7 but it is not. Could there be a MakeMKV-linux (Fedora?) specific problem that seemingly does not exist in the windows version of MakeMKV?
miracoolix
I'm currently using fedora 19 with kernel 3.11.10
uname -a output:
Linux berlin 3.11.10-200.fc19.x86_64 #1 SMP Mon Dec 2 20:28:03 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
and I'm upgrading to fedora 20 right now. But as tramal noted, that wont help that much.
tctc1
Post by tctc1 »
Same issues here, no luck with any BD with Fedora 20 x86_64 and makemkv 1.8.7, please help.
[Linux@F20 ~]$ uname -a
Linux F20 3.12.5-301.fc20.x86_64 #1 SMP Fri Dec 13 22:33:23 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
