So, I have converted over a 100 of my DVD's with makemkv, but I have discovered that in XBMC after about 10 minutes the audio gets out of sync. Testing the same file in VLC and MPC-HC there is no sync issues, works great.
However if I rip with the movie with DVDFab and then use PGCDemux and MKVmerge to make an mkv file there is no audio sync issues in XBMC. So it seems XBMC only has problems with mkv files made with MakeMKV.
It makes me think that the problem is some combination of MakeMKV and XBMC.
Searching around on both forums however, it seems either no one else is using both programs or I have a unique problem all to myself
I tested XBMC's problem on 3 different computers one with XP, one Vista, and one with windows 7, all had the same problem.
I sure would appreciate some ideas of what could be going on here.
