Type: Data - Titles don't load
mrdamour
Post by mrdamour » Sat Dec 14, 2013 2:30 am
Has anyone had this problem? I load a disc that plays fine in stand alone players on in my DVD-Rom drive. I'm using Mavericks on MacOSX. I load the disc into MKV and the type comes up as "Data" and the titles (there are two of them on the disc) don't load. Nothing happens. The "hard disk" icon you would normally press to get the titles available for ripping is greyed out.
Any ideas what I can do?
Thanks.
Re: Type: Data - Titles don't load
Post by Woodstock » Sat Dec 14, 2013 3:51 pm
In several other messages, Mike suggested not inserting the disk into the drive until after MakeMKV was running; have you tried this? This should prevent OSX from imposing its own interpretation of things.
It is also possible that a disk was created as a DVD data disk, rather than a video disk. Logs would be helpful (see signature).
mrdamour
Post by mrdamour » Sat Dec 14, 2013 6:43 pm
I did try starting the program before inserting the disc and that didn't help.
Here are the logs:
001005:0000 MakeMKV v1.8.7 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/———/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE ASUS BW-12D1S-U 1.20d" opened in OS access mode.
001002:0020 LIBMKV_TRACE: BROKEN DIRECTORY ENTRY
001003:0020 DEBUG: Code 0 at Kj*:>q93[MEvI/a'/:121262164
Application exited at Sat Dec 14 15:59:16 2013
I've never seen a playable DVD be recognized as a Data Disc before. Any help is appreciated.
