Saggestions
popovn
Saggestions
#1 Post by popovn » Fri Dec 13, 2013 9:09 am
1) make pls job-list - to ability prepare several jobs and then start them for long time work
2) If I choose file on disk pls, auto-choose output folder as parental folder for my file.
3) if you will use job-list from 1st saggestion - write all warnings only to the log - not screen with "Ok" button
Thank you
Chetwood
Re: Saggestions
#2 Post by Chetwood » Fri Dec 13, 2013 3:38 pm
@1)
If you need the GUI, check my sig, if not search this board for batch converter.
