DVD Menu Shows 3 But MKV Only Makes 2
JimMacMillan
#1 Post by JimMacMillan » Sun Nov 03, 2013 10:40 pm
Hello Everyone,
I'm rendering MKV files from a 70's television series entitled Banacek TVDB Link
On Season 2 Disc 2 the DVD menu shows 3 episodes. They all play on my DVD player but MAKEMKV is only converting 2 of them.
Any thoughts?
Thanks In Advance :)
Jim
JimMacMillan
UPDATE - DVD Menu Shows 3 But MKV Only Makes 2
#2 Post by JimMacMillan » Wed Nov 06, 2013 10:36 pm
Attached is the MakeMKV_log.txt and below is a screenshot of the files in the VIDEO_TS Folder.
As you can see in the screenshot MAKEMKV should be rendering 3 episodes but the log appears to only show 2 for some reason.
MakeMKV_log.txt
MakeMKV_log
(933 Bytes) Downloaded 438 times
JimMacMillan
Re: DVD Menu Shows 3 But MKV Only Makes 2
#3 Post by JimMacMillan » Tue Nov 12, 2013 7:07 am
Does anyone have any thoughts on this? I D/L'd and installed the new version today and it's still not working correctly (at least on this particular DVD).
JimMacMillan
#4 Post by JimMacMillan » Sun Nov 24, 2013 7:21 am
Okay I D/L'd and installed "DVD Decrypter" and ran the DVD through it. Then I ran the decrypted files through MAKEMKV.
I'm still not having any luck with this. I could really use some direction. I don't mind paying for the program if that is what it takes.
Jim
Chetwood
#5 Post by Chetwood » Sun Nov 24, 2013 9:17 am
Apparently the authoring confused MakeMKV so it doesn't see all three eps. What happens when you reauthor the 3eps in DVD Shrink and the open this ISO in MakeMKV?
Wasabi
#6 Post by Wasabi » Tue Dec 10, 2013 11:39 pm
JimMacMillan wrote:Okay I D/L'd and installed "DVD Decrypter" and ran the DVD through it. Then I ran the decrypted files through MAKEMKV.
Jim
Until you get this sorted in MakeMKV, you can use MKVtoolnix to remux the decrypted VOBs into an MKV container.
