Failed to rip The Best Exotic Marigold Hotel
FredTheDog
Post by FredTheDog » Mon Dec 09, 2013 7:35 pm
Am using v1.8.6 on OSX 10.8.5 and having issues with the above. Log file is:
Debug log started at Mon Dec 9 18:46:48 2013 , written by MakeMKV v1.8.6 darwin(x86-release)
001005:0000 MakeMKV v1.8.6 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/grahama/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HE13" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE PIONEER BD-RW BDR-XD04 1.20" opened in DASPI v1.3 mode.
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=jX49Awj4uLKzDHK3+oNYFObbKndeJ/oSet9ngI2me7bQi7RqHjJz3guBtnO2YCcJ/lN/vAqoRU1L2B0PwxmApigxBNeyDZDLiJMMUGVfdSzstkbG66wa1ba6AHehG4SJkdcGTR+4FyCH01Vnf5dMjP75VCGazrOOAA==
DCE=inD4Lm2E4vHVob82OZh+paleBj34cVeT7BM2fenHfkBJ3oEWHV6Bva7gWj8IqRKOGAb2PsKDWbUFi0UYcfdJ7GyLsF/okxMbgszwPMoiivnKGaBgTa7VXoA4zmPUew/nxen917gG6Fzb//OzeOWfaJsZv2lgrx1vtw==
DISCID=749C7A6C8601FD7D7CB20DAB6E93F3D0C772024D
003025:0000 Title #00720.mpls has length of 17 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00001.mpls has length of 71 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #0
003307:0000 File 00801.mpls was added as title #1
003309:0000 Title 00850.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00801.mpls and was skipped
003025:0000 Title #00061.m2ts has length of 33 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 23 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00127.m2ts has length of 15 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00800.m2ts has length of 602 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00062.m2ts has length of 38 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00720.m2ts has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00801.m2ts has length of 602 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00802.m2ts was added as title #2
003025:0000 Title #00803.m2ts has length of 154 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00810.m2ts has length of 86 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00811.m2ts has length of 235 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00812.m2ts has length of 175 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00813.m2ts has length of 165 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00814.m2ts has length of 133 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00815.m2ts has length of 151 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/Media/Movies/The Best Exotic Marigold Hotel
AV sync issues in /Volumes/Media/Movies/The Best Exotic Marigold Hotel/THE_BEST_EXOTIC_MARIGOLD_HOTEL_t00.mkv
AV sync in 1 at 0:10:02.268 (3.666ms) : encountered overlapping frame, audio skew is +3.666ms
001003:0020 DEBUG: Code 1073741829 at F|aK5EwsYb:bo5F*:29393953
001003:0020 DEBUG: Code 2 at 4*QFv]2$L9s\k[>i:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11333203968'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11333793792'
002003:0000 Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11336417280'
002003:0000 Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11336675328'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11337007104'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11339888640'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11343101952'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11345854464'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11346573312'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11346579456'
001003:0020 DEBUG: Code 0 at U/<JJR-nP{])'Nhan/sw:121262739
001003:0020 DEBUG: Code 0 at \B$\Bb\O~'T}QR5ZmDx]:121261888
001003:0020 DEBUG: Code 0 at U/<JJR-nP{])'Nhan/sw:213130743
001003:0020 DEBUG: Code 5540322 at U/<JJR-nP{])'Nhan/sw:29393332
001003:0020 DEBUG: Code 0 at \`UYGfS4/Kui8Q7Rm'$cX:29398622
005003:0000 Failed to save title 0 to file /Volumes/Media/Movies/The Best Exotic Marigold Hotel/THE_BEST_EXOTIC_MARIGOLD_HOTEL_t00.mkv
005004:0080 0 titles saved, 1 failed
Any ideas?
Re: Failed to rip The Best Exotic Marigold Hotel
Post by Woodstock » Tue Dec 10, 2013 9:56 pm
Your drive cannot read parts of the disk. MakeMKV can't work around unreadable media.
First step is to clean the disk. Even minor scratches can cause problems, so I usually use a wax to clean them.
Sometimes the disks themselves have authoring errors, and the only fix is to take it back for replacement.
FredTheDog
Post by FredTheDog » Wed Dec 11, 2013 10:10 am
So its a physical problem with the disk nothing s/w related........Thanks Woodstock
