Failed to rip The Best Exotic Marigold Hotel
FredTheDog
Post by FredTheDog »
Am using v1.8.6 on OSX 10.8.5 and having issues with the above. Log file is:
Debug log started at Mon Dec 9 18:46:48 2013 , written by MakeMKV v1.8.6 darwin(x86-release)
001005:0000 MakeMKV v1.8.6 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/grahama/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-898 HE13" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE PIONEER BD-RW BDR-XD04 1.20" opened in DASPI v1.3 mode.
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=jX49Awj4uLKzDHK3+oNYFObbKndeJ/oSet9ngI2me7bQi7RqHjJz3guBtnO2YCcJ/lN/vAqoRU1L2B0PwxmApigxBNeyDZDLiJMMUGVfdSzstkbG66wa1ba6AHehG4SJkdcGTR+4FyCH01Vnf5dMjP75VCGazrOOAA==
DCE=inD4Lm2E4vHVob82OZh+paleBj34cVeT7BM2fenHfkBJ3oEWHV6Bva7gWj8IqRKOGAb2PsKDWbUFi0UYcfdJ7GyLsF/okxMbgszwPMoiivnKGaBgTa7VXoA4zmPUew/nxen917gG6Fzb//OzeOWfaJsZv2lgrx1vtw==
DISCID=749C7A6C8601FD7D7CB20DAB6E93F3D0C772024D
003025:0000 Title #00720.mpls has length of 17 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00001.mpls has length of 71 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #0
003307:0000 File 00801.mpls was added as title #1
003309:0000 Title 00850.mpls is equal to title 00800.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00801.mpls and was skipped
003025:0000 Title #00061.m2ts has length of 33 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 23 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00127.m2ts has length of 15 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00800.m2ts has length of 602 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00062.m2ts has length of 38 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00720.m2ts has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00801.m2ts has length of 602 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00802.m2ts was added as title #2
003025:0000 Title #00803.m2ts has length of 154 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00810.m2ts has length of 86 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00811.m2ts has length of 235 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00812.m2ts has length of 175 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00813.m2ts has length of 165 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00814.m2ts has length of 133 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00815.m2ts has length of 151 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/Media/Movies/The Best Exotic Marigold Hotel
AV sync issues in /Volumes/Media/Movies/The Best Exotic Marigold Hotel/THE_BEST_EXOTIC_MARIGOLD_HOTEL_t00.mkv
AV sync in 1 at 0:10:02.268 (3.666ms) : encountered overlapping frame, audio skew is +3.666ms
001003:0020 DEBUG: Code 1073741829 at F|aK5EwsYb:bo5F*:29393953
001003:0020 DEBUG: Code 2 at 4*QFv]2$L9s\k[>i:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11333203968'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11333793792'
002003:0000 Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11336417280'
002003:0000 Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11336675328'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11337007104'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11339888640'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11343101952'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11345854464'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11346573312'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '11346579456'
001003:0020 DEBUG: Code 0 at U/<JJR-nP{])'Nhan/sw:121262739
001003:0020 DEBUG: Code 0 at \B$\Bb\O~'T}QR5ZmDx]:121261888
001003:0020 DEBUG: Code 0 at U/<JJR-nP{])'Nhan/sw:213130743
001003:0020 DEBUG: Code 5540322 at U/<JJR-nP{])'Nhan/sw:29393332
001003:0020 DEBUG: Code 0 at \`UYGfS4/Kui8Q7Rm'$cX:29398622
005003:0000 Failed to save title 0 to file /Volumes/Media/Movies/The Best Exotic Marigold Hotel/THE_BEST_EXOTIC_MARIGOLD_HOTEL_t00.mkv
005004:0080 0 titles saved, 1 failed
Any ideas?
Re: Failed to rip The Best Exotic Marigold Hotel
Your drive cannot read parts of the disk. MakeMKV can't work around unreadable media.
First step is to clean the disk. Even minor scratches can cause problems, so I usually use a wax to clean them.
Sometimes the disks themselves have authoring errors, and the only fix is to take it back for replacement.
FredTheDog
So its a physical problem with the disk nothing s/w related........Thanks Woodstock
