Errors running MakeMKV on OS X 10.9 DP
marshalleq
Re: Errors running MakeMKV on OS X 10.9 DP
As you can see, log from windows is very similar.
Debug log started at Sat Aug 24 05:27:18 2013 , written by MakeMKV v1.8.4 win(x64-release)
001005:0000 MakeMKV v1.8.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\username/MakeMKV_log.txt
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=Os+rdZwMCWRhhEsJHDk/z1E1A5XWHaXboZ7SDZNFn6kAdGxnhvI+MlnlGx81rzLCkougmHyGNAfYgoSzf/Sz5f5PZZLRq9O40p+aVhK9whvl6R7y5hPFuQc9xUWHC0GkAc5t8VlJ01YFiTz5nWsj3gaCKO+69jgm6w==
DISCID=6DEA94FB620586CF309C9627EFA6B38B79D8480E
003025:0000 Title #00013.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #0
003025:0000 Title #00000.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00020.mpls was added as title #1
003307:0000 File 00300.mpls was added as title #2
003025:0000 Title #00313.mpls has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00314.mpls has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00315.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00316.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50355.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50360.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50361.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50362.m2ts has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50363.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50364.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50365.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50366.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50367.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 50368.m2ts was added as title #3
003307:0000 File 50369.m2ts was added as title #4
003307:0000 File 50370.m2ts was added as title #5
003307:0000 File 50371.m2ts was added as title #6
003307:0000 File 50372.m2ts was added as title #7
001003:0020 DEBUG: Code 233 at jz0tPI7yHWFijaZtmQG42QHP:0
001003:0020 DEBUG: Code 233 at CxS2zewqDl3IliQNh2hc3+c+:0
001003:0020 DEBUG: Code 233 at Z44et/DeyT9pcMks1zDebpdQ:0
001003:0020 DEBUG: Code 233 at ejB30hyt+VMil+kJSdWUBWad:0
001003:0020 DEBUG: Code 233 at tbY4yR/4O7uah/toQhiKQKpO:0
001003:0020 DEBUG: Code 233 at kpZ1EDtD/N+vABo1VAqmdKnV:0
001003:0020 DEBUG: Code 233 at ptbJJ72IixTynZEfCEAlLBte:0
001003:0020 DEBUG: Code 233 at +OJDkUtLB6V5rSxLKPBnmLOp:0
001003:0020 DEBUG: Code 233 at dXoa1wGbJB4gzUgyhO/rl3Th:0
001003:0020 DEBUG: Code 233 at rU3xZjr3QCLBzPYgYYAlr5e6:0
csf9
csf6
Application exited at Sat Aug 24 05:28:28 2013
csf9
csf6
marshalleq
Downgraded to 1.8.2 and managed to get a complete rip. Seems to be more stable. On OSX 10.9 DP6
unipacfr
MakeMKV 1.8.4 crashing randomly on 10.9 DP6 with a Samsung external Bluray player with the error message "Fatal error occurred, program will now exit."
Crashing occurs too with the 1.8.3 version
This shoud be fixed in 1.8.5 . But please, if you get a crash on 10.9, please collect and submit a quick problem report per instructions at /onlinehelp/dump.html .
liner
Excellent, when can we look forward to this release?mike admin wrote:This shoud be fixed in 1.8.5 . But please, if you get a crash on 10.9, please collect and submit a quick problem report per instructions at /onlinehelp/dump.html .
thelegume
I am running OSX 10.9 beta 7 and MakeMKV 1.8.4. In trying to create a full core dump on OSX per the dump instruction page http://www.makemkv.com/onlinehelp/dump.html, but no cores.XXXX appear in terminal after following step 6. Instead, this is the message that I am getting in terminal when the error appears in MakeMKV:
makemkvcon(53340,0xb029b000) malloc: *** mach_vm_map(size=8388608) failed (error code=3)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
Fatal error - out of memory
2013-09-07 22:12:28.670 makemkv[53339:507] modalSession has been exited prematurely - check for a reentrant call to endModalSession:
unipacfr
Same here on a macbook pro retina
makemkvcon(548,0xb029b000) malloc: *** mach_vm_map(size=8388608) failed (error code=3)
2013-09-09 11:45:13.785 makemkv[547:507] modalSession has been exited prematurely - check for a reentrant call to endModalSession:
thelegume
1.8.5 has resolved these errors for me and all blurays are ripping just fine now. Thanks!
Antoine
I had the same issue with MakeMkv 1.8.3. I run OSX 10.9 Mavericks on my Mid-2009 MBP and every time I was trying to rip a DVD (French DVDs), the software crashed, announcing a fatal error.
I downloaded the 1.8.5 version but was not able to run it for awhile (the system blocked its execution as the developer of the software was somehow not identified to OSX - I ended up learning about how to circumvent this security block).
Finally, MakeMkv seems back to functioning properly (1 success so far).
Sincerely,
Antoine
Sincerely,
Antoine
jefftr
Using 1.8.6 and 10.9. Whenever I try to change to default disc - either in the program or in preferences the program either freezes or crashes.
whitehusky
I've also been getting the fatal error on 10.9 Mavericks for months now. Works perfect on 10.8, but crashes a ton on 10.9. Hard to even get a single rip done.
