Youth in Revolt - Doesn't save to disk
jonro
Post by jonro » Fri Dec 06, 2013 1:18 pm
MakeMKV v1.8.6 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KC12" opened in DASPI v1.4 mode.
Optical drive "BD-ROM hp DVDWBD TS-LB23L 0600" opened in DASPI v1.4 mode.
Title #00666.mpls has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.mpls was added as title #0
Title #00102.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00999.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.mpls has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.mpls(1) has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00032.mpls was added as title #1
Title #00033.mpls has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.mpls has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.mpls has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.mpls has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.mpls has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00038.mpls was added as title #2
Title #00039.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.mpls has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.mpls has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.mpls has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00045.mpls was added as title #3
Title #00046.mpls has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00047.mpls was added as title #4
File 00048.mpls was added as title #5
Title #00099.mpls has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00051.mpls was added as title #6
File 00053.mpls was added as title #7
File 00057.mpls was added as title #8
Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00107.m2ts was added as title #9
Title #00106.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00112.m2ts was added as title #10
Title #00113.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00119.m2ts was added as title #11
Title #00120.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00121.m2ts was added as title #12
Title #00122.m2ts has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00125.m2ts was added as title #13
File 00126.m2ts was added as title #14
File 00127.m2ts was added as title #15
Title #00128.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00129.m2ts was added as title #16
File 00130.m2ts was added as title #17
File 00131.m2ts was added as title #18
Title #00235.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00266.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00267.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/jarp/Movies/Youth_In_Revolt_(2010)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '6011486208'
Failed to save title 0 to file /Users/jarp/Movies/Youth_In_Revolt_(2010)/Youth_In_Revolt_(2010)_t00.mkv
0 titles saved, 1 failed
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '6013188096'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '6013194240'
Failed to save title 0 to file /Users/jarp/Movies/Youth_In_Revolt/Youth_In_Revolt_t00.mkv
Re: Youth in Revolt - Doesn't save to disk
Post by Woodstock » Fri Dec 06, 2013 3:49 pm
Your drive can't read the disk in several locations. Sometimes, cleaning the disk, or setting the number of retries to 10 instead of 5. can work around a marginal disk, but there is something wrong with the disk.
