Why Make MKV find two similar tracks?
ponzo79
#1 Post by ponzo79 » Sun Dec 01, 2013 1:30 pm
Hello and sorry for my english
I'm a new user in this forum
I want convert to a blu ray disc (lord of the rings fellowship of the ring extended edition part 2) but Make MKV find two similar tracks....
which one to use?
toshibauser
Re: Why Make MKV find two similar tracks?
#2 Post by toshibauser » Sun Dec 01, 2013 10:59 pm
I'm also a newbie with MMkv but the key here is to pay attention.
Pop the disc in a standalone player en verify the exact length and number of chapters, then compare with those with tracks in MMkv.
It will be evident which is the correct one.
#3 Post by Woodstock » Mon Dec 02, 2013 5:20 am
There can be dozens of "similar" tracks on some titles. Sometimes, these contain versions that vary only in some signs or other text in the background that are different for different languages. Sometimes, many will have scrambled scene lists, in an attempt to confuse users as to which one is real.
toshibauser's suggestion is the first step - checking times vs. what the BD's menu says is the "right" track.
ponzo79
#4 Post by ponzo79 » Mon Dec 02, 2013 9:10 am
Thank your answer, but my tracks are very very similar....I'm a newbie but I am not stupid...I use MakeMKV from two years
The chapters are equal (21)
Languages and subtitles are equal
Size file .iso 36,33 GB
I converter all tracks and this is result:
File name track 1: 00001.MPLS
Size track 1: 29,36 GB
Length track 1: 2:02:34 (h:m:s)
File name track 2: 01689.MPLS
Size track 2: 29,36 GB
Length track 2: 2:02:37 (h:m:s)
I deleted all languages and subtitles except italian.
The length difference is because the track two start 3 seconds after
I checked both tracks but I do not find differences
Sorry for my english...
Smithcraft
#5 Post by Smithcraft » Tue Dec 03, 2013 9:07 am
One iDea suggested by setarip_old was to just back the disc up, and then try the segments from the segment map and see what's what.
Or maybe check the BDInfo DB and see if that disc has been listed and read the report on it.
SC
bw001
#6 Post by bw001 » Tue Dec 03, 2013 3:20 pm
Both tracks contain segment 10 which is the main part of part 2 of the movie.
The second track contains segment 24 which is an additional 3 seconds at the beginning of that track.
I don't remember, but it may be black video to bridge between part one and part two.
You can rip both and play them and see what's at the beginning of the 2nd track (first 3 seconds), or do what Smithcraft suggests and back it up and play segment 24.
ponzo79
#7 Post by ponzo79 » Tue Dec 03, 2013 5:09 pm
SC
Thank you for your answers
But, i don't understand what you mean...
I checked the first second, and are black.
The video start three seconds later in the second track
Explain me please
bw001
#8 Post by bw001 » Wed Dec 04, 2013 2:07 pm
Either track will give you part 2 of the main movie.
The second track includes 3 seconds of blank video.
ponzo79
#9 Post by ponzo79 » Thu Dec 05, 2013 4:35 pm
bw001 wrote:The second track includes 3 seconds of blank video.
For you it's only this the difference?
Thank you very much
toshibauser
#10 Post by toshibauser » Fri Dec 06, 2013 4:49 am
Don't forget also that (typically) there are at least 2 versions on many discs, such as "director's cut", "theatrical version", "extended version" etc etc.
