Installation problems ...
langstracht
Post by langstracht »
I used the instructions listed on:
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224
the step:
make -f makefile.linux
on:
makemkv-oss-1.8.6
results in the following error:
make: *** [out/libmakemkv.so.1.full] Error 1
and sure enough in trying to run:
makmkvcon
I get the error message:
error while loading shared libraries: libmakemkv.so.1: cannot open shared object file: No such file or directory
It would appear that makeMKV rocks and I would REALLY like to use it.
Can anyone get me over this problem?
Thanks in advance.
Re: Installation problems ...
In the "Stickies" section of this forum, there is a message "Workaround for 1.8.6 compilation issues". Have you read and tried that yet?
langstracht
I had not ... principally because I did not know it was there.
Just to be sure it's the right one I assume you mean the directive to:
./configure
make
sudo make install
On doing so I get the following VERY disappointing results;
./configure
gave a bunch of yes-es but the following that "look" wrong:
checking for AVFrame.nb_samples... no
checking whether AV_SAMPLE_FMT_U8P is declared... no
checking for avcodec_encode_audio2... no
configure: error: The libavcodec library is too old. Please get a recent one from http://www.ffmpeg.org
sudo make install
make
results in the error message:
make: *** No targets specified and no makefile found. Stop.
and
sudo make install
make: *** No rule to make target `install'. Stop.
Very much look forward to resolution of this ...
langstracht
I had not.
Doing so resulted in the following:
./configure
seemed to return a whole bunch of yeses - which I assume is good - but the following "errors":
make
resulted in:
And perhaps unsurprisingly
sudo make install
resulted in:
A rather disappointing outcome ...
Very much look forward to a resolution.
