Also Problems with 1.8.6 Compilation
i have also tried to compile makemkv-oss/bin unsuccessfully.
Here you can see my results: http://pastebin.com/2KYfQngB
Therefore i have installed ffmpeg from deb-repo, but this doesn't solve the problem.
ffmpeg -version
FFmpeg version SVN-r0.5.10-4:0.5.10-1, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --extra-version=4:0.5.10-1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdc1394 --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
libpostproc 51. 2. 0 / 51. 2. 0
built on Feb 16 2013 09:22:58, gcc: 4.4.5
FFmpeg SVN-r0.5.10-4:0.5.10-1
Can you can help me please?!
Thanks in advance!
ffmpeg -version
Thanks in advance!
Re: Also Problems with 1.8.6 Compilation
Your ffmpeg is way too old. You need 2.0 to build without patches. 1.2 can be allegedly made to work, but this is yet to be confirmed
thanks for your answer!
@Okay, i have compiled the newest ffmpeg and now i'm stuck with another error (with the new 1.8.6-oss-cfg1-Package):
But the libavcodec is newly compiled with the ffmpeg,too.
Do you have another trick for me?!
root@openmediavault:~/makemkv-oss-1.8.6# /usr/local/bin/ffmpeg -version
ffmpeg version 2.1.1
built on Nov 27 2013 22:05:21 with gcc 4.4.5 (Debian 4.4.5-8)
configuration:
libavutil 52. 48.101 / 52. 48.101
libavcodec 55. 39.101 / 55. 39.101
libavformat 55. 19.104 / 55. 19.104
libavdevice 55. 5.100 / 55. 5.100
libavfilter 3. 90.100 / 3. 90.100
libswscale 2. 5.101 / 2. 5.101
libswresample 0. 17.104 / 0. 17.104
root@openmediavault:~/makemkv-oss-1.8.6# make
mkdir -p out
gcc -g -O2 -D_GNU_SOURCE -D_linux_ -D_REENTRANT -shared -Wl,-z,defs -oout/libmakemkv.so.1.full -Ilibebml/inc -DEBML_NO_READ -DEBML_STRICT_API -Ilibmatroska/inc \
-Ilibmakemkv/inc -Isstring/inc -Imakemkvgui/inc -Ilibabi/inc -Ilibffabi/inc \
libebml/src/EbmlBinary.cpp libebml/src/EbmlContexts.cpp libebml/src/EbmlCrc32.cpp libebml/src/EbmlDate.cpp libebml/src/EbmlDummy.cpp libebml/src/EbmlElement.cpp libebml/src/EbmlFloat.cpp libebml/src/EbmlHead.cpp libebml/src/EbmlMaster.cpp libebml/src/EbmlSInteger.cpp libebml/src/EbmlString.cpp libebml/src/EbmlSubHead.cpp libebml/src/EbmlUInteger.cpp libebml/src/EbmlUnicodeString.cpp libebml/src/EbmlVersion.cpp libebml/src/EbmlVoid.cpp libebml/src/IOCallback.cpp libebml/src/MemIOCallback.cpp libmatroska/src/FileKax.cpp libmatroska/src/KaxAttached.cpp libmatroska/src/KaxAttachments.cpp libmatroska/src/KaxBlock.cpp libmatroska/src/KaxBlockData.cpp libmatroska/src/KaxChapters.cpp libmatroska/src/KaxCluster.cpp libmatroska/src/KaxClusterData.cpp libmatroska/src/KaxContentEncoding.cpp libmatroska/src/KaxContexts.cpp libmatroska/src/KaxCues.cpp libmatroska/src/KaxCuesData.cpp libmatroska/src/KaxInfo.cpp libmatroska/src/KaxInfoData.cpp libmatroska/src/KaxSeekHead.cpp libmatroska/src/KaxSegment.cpp libmatroska/src/KaxTag.cpp libmatroska/src/KaxTags.cpp libmatroska/src/KaxTrackAudio.cpp libmatroska/src/KaxTrackEntryData.cpp libmatroska/src/KaxTracks.cpp libmatroska/src/KaxTrackVideo.cpp libmatroska/src/KaxVersion.cpp libmakemkv/src/ebmlwrite.cpp libmakemkv/src/libmkv.cpp libmakemkv/src/version.cpp libmakemkv/src/world.cpp sstring/src/sstring.cpp \
libabi/src/ossl_aes.c libabi/src/ossl_sha.c libabi/src/ossl_ec.c libabi/src/zlib.c libabi/src/xpat.c libabi/pssl/ec_key.c libabi/pssl/ec_lib.c libabi/pssl/ec_cvt.c libabi/pssl/ec_mult.c libabi/pssl/ecp_mont.c libabi/pssl/ecp_smpl.c libabi/pssl/ecs_ossl.c libabi/pssl/ecs_sign.c libabi/pssl/ecs_vrf.c libabi/src/httplinux.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.c makemkvgui/src/spawn_posix.cpp libffabi/src/ffabi.c libffabi/src/mlp.c libffabi/src/log.c libffabi/src/audio_convert.c \
-DHAVE_BUILDINFO_H -Itmp -I/usr/local/include \
-fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -pthread -L/usr/local/lib -lavcodec -ldl -lasound -lz -lrt -lavutil -lm -lm
/usr/bin/ld: /usr/local/lib/libavcodec.a(allcodecs.o): relocation R_X86_64_32 against `ff_a64multi_encoder' can not be used when making a shared object; recompile with -fPIC
/usr/local/lib/libavcodec.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make: *** [out/libmakemkv.so.1.full] Fehler 1
I also have this problem. exact same error.Chribu wrote:Hi,
But the libavcodec is newly compiled with the ffmpeg,too.Code: Select all
root@openmediavault:~/makemkv-oss-1.8.6# /usr/local/bin/ffmpeg -version ffmpeg version 2.1.1 built on Nov 27 2013 22:05:21 with gcc 4.4.5 (Debian 4.4.5-8) configuration: libavutil 52. 48.101 / 52. 48.101 libavcodec 55. 39.101 / 55. 39.101 libavformat 55. 19.104 / 55. 19.104 libavdevice 55. 5.100 / 55. 5.100 libavfilter 3. 90.100 / 3. 90.100 libswscale 2. 5.101 / 2. 5.101 libswresample 0. 17.104 / 0. 17.104 root@openmediavault:~/makemkv-oss-1.8.6# make mkdir -p out gcc -g -O2 -D_GNU_SOURCE -D_linux_ -D_REENTRANT -shared -Wl,-z,defs -oout/libmakemkv.so.1.full -Ilibebml/inc -DEBML_NO_READ -DEBML_STRICT_API -Ilibmatroska/inc \ -Ilibmakemkv/inc -Isstring/inc -Imakemkvgui/inc -Ilibabi/inc -Ilibffabi/inc \ libebml/src/EbmlBinary.cpp libebml/src/EbmlContexts.cpp libebml/src/EbmlCrc32.cpp libebml/src/EbmlDate.cpp libebml/src/EbmlDummy.cpp libebml/src/EbmlElement.cpp libebml/src/EbmlFloat.cpp libebml/src/EbmlHead.cpp libebml/src/EbmlMaster.cpp libebml/src/EbmlSInteger.cpp libebml/src/EbmlString.cpp libebml/src/EbmlSubHead.cpp libebml/src/EbmlUInteger.cpp libebml/src/EbmlUnicodeString.cpp libebml/src/EbmlVersion.cpp libebml/src/EbmlVoid.cpp libebml/src/IOCallback.cpp libebml/src/MemIOCallback.cpp libmatroska/src/FileKax.cpp libmatroska/src/KaxAttached.cpp libmatroska/src/KaxAttachments.cpp libmatroska/src/KaxBlock.cpp libmatroska/src/KaxBlockData.cpp libmatroska/src/KaxChapters.cpp libmatroska/src/KaxCluster.cpp libmatroska/src/KaxClusterData.cpp libmatroska/src/KaxContentEncoding.cpp libmatroska/src/KaxContexts.cpp libmatroska/src/KaxCues.cpp libmatroska/src/KaxCuesData.cpp libmatroska/src/KaxInfo.cpp libmatroska/src/KaxInfoData.cpp libmatroska/src/KaxSeekHead.cpp libmatroska/src/KaxSegment.cpp libmatroska/src/KaxTag.cpp libmatroska/src/KaxTags.cpp libmatroska/src/KaxTrackAudio.cpp libmatroska/src/KaxTrackEntryData.cpp libmatroska/src/KaxTracks.cpp libmatroska/src/KaxTrackVideo.cpp libmatroska/src/KaxVersion.cpp libmakemkv/src/ebmlwrite.cpp libmakemkv/src/libmkv.cpp libmakemkv/src/version.cpp libmakemkv/src/world.cpp sstring/src/sstring.cpp \ libabi/src/ossl_aes.c libabi/src/ossl_sha.c libabi/src/ossl_ec.c libabi/src/zlib.c libabi/src/xpat.c libabi/pssl/ec_key.c libabi/pssl/ec_lib.c libabi/pssl/ec_cvt.c libabi/pssl/ec_mult.c libabi/pssl/ecp_mont.c libabi/pssl/ecp_smpl.c libabi/pssl/ecs_ossl.c libabi/pssl/ecs_sign.c libabi/pssl/ecs_vrf.c libabi/src/httplinux.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.c makemkvgui/src/spawn_posix.cpp libffabi/src/ffabi.c libffabi/src/mlp.c libffabi/src/log.c libffabi/src/audio_convert.c \ -DHAVE_BUILDINFO_H -Itmp -I/usr/local/include \ -fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \ -Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -pthread -L/usr/local/lib -lavcodec -ldl -lasound -lz -lrt -lavutil -lm -lm /usr/bin/ld: /usr/local/lib/libavcodec.a(allcodecs.o): relocation R_X86_64_32 against `ff_a64multi_encoder' can not be used when making a shared object; recompile with -fPIC /usr/local/lib/libavcodec.a: could not read symbols: Bad value collect2: ld returned 1 exit status make: *** [out/libmakemkv.so.1.full] Fehler 1 root@openmediavault:~/makemkv-oss-1.8.6#
Do you have another trick for me?!![]()
I had similar error but `ffh263_vaapi_hwaccel` after recompiling ffmpeg with --enable-pic I now get I different error.
/usr/bin/ld: /usr/local/lib/libavcodec.a(mqc.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
/usr/local/lib/libavcodec.a: could not read symbols: Bad valueCode: Select all
ffmpeg version git-2013-09-18-ea70e2f Copyright (c) 2000-2013 the FFmpeg developers
built on Dec 1 2013 12:31:16 with gcc 4.7 (Ubuntu/Linaro 4.7.3-1ubuntu1)
configuration: --enable-gpl --enable-libass --enable-libfaac --enable-libfdk-aac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libspeex --enable-librtmp --enable-libtheora --enable-libvorbis --enable-libvpx --enable-x11grab --enable-libx264 --enable-nonfree --enable-version3 --enable-vdpau --enable-opencl --enable-libopus --enable-pic --extra-cflags='-march=native -I/usr/local/include' --extra-ldflags=-L/usr/local/lib --extra-libs=-ldlRe: Also Problems with 1.8.6 Compilation
I'm getting the exact same thing too, on an up to date ubuntu 13.10 installation with libav and ffmpeg both installed.res0r9lm wrote:I had similar error but `ffh263_vaapi_hwaccel` after recompiling ffmpeg with --enable-pic I now get I different error.Code: Select all
/usr/bin/ld: /usr/local/lib/libavcodec.a(mqc.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/local/lib/libavcodec.a: could not read symbols: Bad valueCode: Select all
ffmpeg version git-2013-09-18-ea70e2f Copyright (c) 2000-2013 the FFmpeg developers built on Dec 1 2013 12:31:16 with gcc 4.7 (Ubuntu/Linaro 4.7.3-1ubuntu1) configuration: --enable-gpl --enable-libass --enable-libfaac --enable-libfdk-aac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libspeex --enable-librtmp --enable-libtheora --enable-libvorbis --enable-libvpx --enable-x11grab --enable-libx264 --enable-nonfree --enable-version3 --enable-vdpau --enable-opencl --enable-libopus --enable-pic --extra-cflags='-march=native -I/usr/local/include' --extra-ldflags=-L/usr/local/lib --extra-libs=-ldl
So very broken... I'm just going to carry on using 1.8.5 until this is resolved...
Hint: Other strongly ffmpeg-dependent software, eg: handbrake, xbmc, download and link their own known-good ffmpeg (if you're building from source, and on that subject, maybe it's time for a .deb repository?). Yes, this makes the build process take longer. Yes, it works. After all, presumably the Windows/OSX builds have their own ffmpeg bundled? There's not actually a good reason for keeping it complicated on linux, at least for the most popular distros.
I have the same problem.
I can get past the makemkv compile error by compiling ffmpeg with these flags:
./configure --disable-static --enable-shared --enable-nonfree --enable-gpl
However whenever I launch makemkv the dialog never shows on the screen. So something else isn't right.
I am doing this on Ubuntu 13.10. I had no issues when running on Arch (ffmpeg was already 2.1.1).
I was able to get this to work on Ubuntu 13.10 (well Linux Mint 16).
I downloaded ffmpeg v2.1.1 from ffmpeg website: http://www.ffmpeg.org/releases/ffmpeg-2.1.1.tar.bz2.
Then I configured ffmpeg v2.1.1 with these options:
I added each dependency from apt one at a time until I got them all.
Then:
Then I built the original makemkv 1.8.6 (not the published 'fix' from here: http://www.makemkv.com/forum2/viewtopic.php?f=3&t=7252) like the original instructions called for. So far everything is working perfectly (24-bit flac conversion!). This was a pain in the butt. I hope this helps others.
./configure --enable-shared --disable-stripping --enable-gpl --enable-version3 --enable-runtime-cpudetect --enable-postproc --enable-x11grab --enable-libcdio --enable-vaapi --enable-vdpau --enable-bzlib --enable-gnutls --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libfaac --enable-libvo-aacenc --enable-nonfree --enable-libmp3lame --enable-libx264 --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfdk_aac --enable-libopus --enable-pthreads --enable-zlib --enable-libvpx --enable-libfreetype --enable-libpulseThen:
sudo make install
sudo make install-libs
I got this to work by changing the config options for ffmpeg when building from source. This works on Linux Mint 16 so I'm assuming it will be the same for all Ubuntu 13.10 derivatives.
I used the latest ffmpeg 2.1.1 source from their website.
Configure with these options:
I added each dependency from apt one at at time.
Then I ran:
Then I used the original 1.8.6 oss package. Everything works perfectly including 24-bit flac conversion.
Then I ran:
make
sudo make install
Didn't work for me.dwalme wrote:I got this to work by changing the config options for ffmpeg when building from source. This works on Linux Mint 16 so I'm assuming it will be the same for all Ubuntu 13.10 derivatives.
Configure with these options:I added each dependency from apt one at at time.Code: Select all
Then I ran:Then I used the original 1.8.6 oss package. Everything works perfectly including 24-bit flac conversion.Code: Select all
make sudo make install sudo make install-libs
got ffmpeg 2.1.1 installed OK. Building the 1.8.6-cfg tarball worked, but when I tried to run makemkv, it just hung, with makemkvcon taking up 100% cpu.
rachel@twilight:~$ ldd $(which makemkvcon) | grep libav
libavcodec.so.55 => /usr/local/lib/libavcodec.so.55 (0x00007f2332c3c000)
libavutil.so.52 => /usr/local/lib/libavutil.so.52 (0x00007f23329eb000)
Guys, hate having to go there, but... I am a paying customer, and now it's broken, for the sake of a feature I don't even want.
This needs a fix.
Make debs that work. Statically link ffmpeg.
This needs a fix.
FWIW added --enable-pic to those flags as per thread http://www.makemkv.com/forum2/viewtopic.php?f=3&t=7225 but it didn't make any difference. Still hangs on start.
Re-downloaded, rebuilt 1.8.5. it works.
- Contact:
Fixed in 1.8.7 , available for download.rachel wrote:Still hangs on start.
Confirmed for me.mike admin wrote:Fixed in 1.8.7 , available for download.rachel wrote:Still hangs on start.
Not actually using the FLAC functionality it links to ffmpeg *for*, so can't speak to whether that works, but at least it no longer prevents the core functionality from working.
Yay, fixed in time for christmas!
