Scarface
galager
Scarface
Post by galager »
I keep getting errors when trying to backup my Scarface Blu Ray. Whem I just play the disk it works fine. I tried both 36 GB titles on the disk. One is the 800.m2ts file below and the other is 800.mpls. Both give me the same issue...
Saving 1 titles into directory Z:/Movies
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1274277888'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1274474496'
Failed to save title 0 to file Z:/Movies/Scarface_t00.mkv
0 titles saved, 1 failed
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1275985920'
Failed to save title 12 to file Z:/Movies/Scarface_t12.mkv
Saving 2 titles into directory Z:/Movies
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1274935296'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1274947584'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1275396096'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1275525120'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '1275531264'
0 titles saved, 2 failed
crowfax
Re: Scarface
Post by crowfax »
this is a symptom of a poorly pressed disc. Swap it for a new one.
galager
Re: Scarface
Post by galager »
Even though it plays back fine? Backing it up is more sensitive than playback?
Re: Scarface
Playback: If there is an error, skip over it best you can and continue.
Ripping or Backing up: If there is an error, the file is corrupted.
So, yes, playback on a standard player will skip over bad spots. But, even a lot of computer players will stop on an error.
