The Wolverine Region AB
thedo
Post by thedo »
Get some errors about no FUTs obtained and the Bluray rips but is very macro blocky.
Apparently it's AACS v36, BD+ 2013.10. Uploading the dump if thats useful
[url downloaded]
Noodles
Re: The Wolverine Region AB
Post by Noodles »
Is there any chance that the developers will have a look at this and hopefully fix it??
thedo
Post by thedo »
Works for me now. Thanks for the awesomely fast turnaround!
rj4579
Post by rj4579 »
Hello, i have the same problem, how did u make it work? ;)
Unless your system has it disabled or blocked, MakeMKV will contact the main server and ask for any "SVQ" files necessary to decode disks that do not use the standard methods. Within MakeMKV, this is controlled under Tools->General->Allow contacting web server for updates. You can also set a directory for these updates to be stored, as the "MakeMKV data directory"; I set up a special one, separate from the program directory.
When disks can't be decoded using the information in the current version of the program, a query is sent out for any disk-specific SVQ files. If one is found, it will be downloaded and used to decode the disk. If none are found, you will USUALLY get a message about a file being created on your system with the information necessary for Mike to create the SVQ file, the path to that file, and a note to please send it to svq@makemkv.com ... That's what thedo did here, and the SVQ data was updated.
More information can be found here: http://www.makemkv.com/svq/
danielch
Post by danielch »
Hello, I have a region C The Wolverine.
The same error message shows up.
Please find the dump https://www.dropbox.com/s/ak1vuemuwriae ... 1012B8.tgz.
Thanks.
Wanderer
Post by Wanderer »
HI, I am getting the same Futs error on my UK Wolverine version, I have saved the log on my drive in case you need to see this, if so, let me know where to copy and paste,
Regards,
Craig
rj4579
Post by rj4579 »
It works for me now, thanks :)
