Failure To Save Title
minou
Post by minou »
I have the following problem with "Dark Knight"
AACS directory not present, assuming unencrypted disc
Title #0 has length of 11 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #1 has length of 5 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 5 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 10 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 17 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 50 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 60 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 3 titles into directory O:/Dark Knight
FAILURE: Code 0 at ;Jjj)nXbrsd<3~~ ]:YL:121262555
FAILURE: Code 0 at f':f}%b4@'EYWUB{m~AH:213130444
FAILURE: Code 4867692 at f':f}%b4@'EYWUB{m~AH:213129639
Failed to save title 2 to file O:/Dark Knight/title02.mkv
2 titles saved, 1 failed
AnyDVD was running but I have also tried it without AnyDVD, with the same result.
Any ideas?
Minou
Re: Failure To Save Title
Post by mike admin »
Hi, Minou!
We checked this out. The error says that you've got damaged disc (or file).
PierreLo
Post by PierreLo »
Well Mike,
I am not sure. I got this "failed to save title" error quite often these days, and DVDs were in excellent shape, no scratch, nothing.
What looks strange is that the whole process seems to go fine, but only in the end it won't save the file.
I thought about a folder name problem, but I tried on very simple folder names and it was the same.
I tried to find the mkv temp file (the one before saving occurs) but I couldn't.
is there any temp file ?
PierreLo 8)
pchristoph
Post by pchristoph »
I am having the same issue. I am using a source DVD on an external USB Hard Disk (G drive, enough disk space) and tried the following:
1) Only use main movie with German language & subtitle tracks -> Export to G drive, but different folder
Opening files on harddrive at G:/My Videos/DVD_Rips/Zodiac/VIDEO_TS/
Calculated BUP offset does not match one in IFO header.
Title #0 was added (28 cell(s), 2:30:59)
Title #1 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 was added (1 cell(s), 0:27:00)
Title #3 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory G:/Video/WARNER_HOME_VIDEO_(Fab5050)
FAILURE: Code 672 at c\MX<[Rhgq(}h~L=N~b$):29394896
FAILURE: Code 768 at c\MX<[Rhgq(}h~L=N~b$):29394896
FAILURE: Code 576 at c\MX<[Rhgq(}h~L=N~b$):29394390
FAILURE: Code 49 at r-'tbk'_px 8{|y\H2&:121265131
FAILURE: Code 0 at c\MX<[Rhgq(}h~L=N~b$):29395885
Failed to save title 0 to file G:/Video/WARNER_HOME_VIDEO_(Fab5050)/title00.mkv
0 titles saved, 1 failed
2) Select all titles with all languages & subtitle tracks -> Export to C drive (Temp Folder, enough disc space)
Saving 2 titles into directory C:/temp
FAILURE: Code 288 at c\MX<[Rhgq(}h~L=N~b$):29394896
FAILURE: Code 1344 at c\MX<[Rhgq(}h~L=N~b$):29394390
Failed to save title 0 to file C:/temp/title00.mkv
1 titles saved, 1 failed
The main movie (Title 0) was not save, some bonus material (Title 1) was saved.
I can see that there also seems to be an issue with reading the source file(s). Do you happen do know any tools to fix this cause when playing the DVD with VLC I am not having any issues at all.
Cheers,
Christoph
