Greetings,
MakeMKV is reliably crashing every time it tries to do just about anything, for example opening a drive, with a "fatal error" message. It works on a couple of other very similar machines without a single issue, the only obvious difference being that this particular computer has two RAID arrays, 12TB and 6TB in size... which, by contemporary standards, are not even that large. They do have 4K sectors and GPT partitions, however. OS is windows 8, up to date, PowerDVD is installed, Alcohol 120% is installed... nothing else out of the ordinary.
Any suggestions?
-A
MakeMKV crashes on machine with large drives?
- Crash dialog box
- makemkv_crash.png (9.1 KiB) Viewed 4025 times
- Contact:
Re: MakeMKV crashes on machine with large drives?
There should be something else. Please try to capture the debug dump per /onlinehelp/dump.html
