Tintin Bluray fails to save title...plays fine on BD player
sdkretschek
Post by sdkretschek »
I only selected title 00, 28 GB, 16 chapters to save to disk.
Saving 1 titles into directory /Users/newapple/Movies/Adventures Of Tintin
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00352.m2ts' at offset '4240896000'
Failed to save title 0 to file /Users/newapple/Movies/Adventures Of Tintin/The_Adventures_of_Tintin_t00.mkv
0 titles saved, 1 failed
crowfax
Re: Tintin Bluray fails to save title...plays fine on BD pla
Post by crowfax »
dirty or damaged disc, swap it for a new one.
sdkretschek
Maybe a dumb question, but, wouldn't I expect to see read errors when the disc is being scanned?
crowfax
Post by crowfax »
No. Not until it starts trying to copy bit for bit.
In addition to what crowfax said, the scanning process looks at the directory structure of the disk, and validates the "pieces". It only reads a fraction of the disk, but any read errors found there would be reported during the scan.
audiopimp
Re: Tintin Bluray fails to save title...plays fine on BD player
Post by audiopimp »
I've just bought it on Blu-Ray from eBay, and have the same problem. It seems to be on the first disc only, as the other 4 out of the 5 discs in the box set are fine.
Did anyone find an answer?
I've cleaned the disc. Looks new. I may have to take it down to CEX for a thorough clean.
Tried other blu-rays - No problems with any of them.
Plays perfectly in the Blu-ray player.
Here's a small sample of the 336 errors from
DISC ONE (5 files, 1 saved 'The Broken Ear')
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '660142080'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '663355392'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '663945216'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '663945216'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '664928256'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '665579520'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '667809792'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '667809792'
Encountered 336 errors of type 'Read Error'
DISC TWO (5 files, 5 saved)
DISC THREE (5 files, 5 saved)
DISC FOUR (5 files, 5 saved)
DISC FIVE (3 files, 3 saved)
Perfex
Post by Perfex »
Same issue...
However I was able to pull The Black Island, The Blue Lotus, and The Broken Ear from the disc by selecting the titles individually.
Tintin in America and Cigars of the Pharaoh will stop around 378.5m.
audiopimp
Post by audiopimp »
Wow! So it seems to be a bad pressing on Disc 1 only then?
Perfex
Post by Perfex »
I’m not sure if it’s the disc or MKV at this point, the Disc 1 of the DVD set acts in a similar manner.
