Copy complete. 0 titles saved, 1 failed.
kbarry
Post by kbarry » Thu Nov 14, 2013 9:21 pm
I'm using MKV 1.8.6 for mac. Just recently purchased the complete Bond 007 DVD set and want copies to load onto my Smart TV so I don't have to use the discs. The first 4 DVDs wrote w/o incident, now I'm getting this error message on the last 4 I've tried to write to m4v's.
Debug log started at Thu Nov 14 20:59:48 2013 , written by MakeMKV v1.8.6 darwin(x86-release)
001005:0000 MakeMKV v1.8.6 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/kimbarry/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL PIONEER DVD-RW DVR-K06A Q624d" opened in OS access mode.
003025:0000 Title #1 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/1 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/2 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/3 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/4 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/5 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/6 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/7 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/8 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/9 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8/10 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 35-end were skipped due to cell commands (structure protection?)
003028:0000 Title #11 was added (34 cell(s), 2:01:14)
Title skip vts=10 pgcn=1 hash=3F3B597BE86D9FA0
003025:0000 Title #13 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #15 has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at BUvt5Xk/Pql4YTHk2Y83uHx0:0
005014:0000 Saving 1 titles into directory /Users/kimbarry/Movies/Live_and_Let_Die
001003:0020 DEBUG: Code 1073741829 at F|aK5EwsYb:bo5F*:29393953
001003:0020 DEBUG: Code 2 at 4*QFv]2$L9s\k[>i:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_10_1.VOB' at offset '285530112'
001003:0020 DEBUG: Code 0 at U/<JJR-nP{])'Nhan/sw:121262739
001003:0020 DEBUG: Code 0 at d]l9[+tGf|LhkjwvuP\:121261681
001003:0020 DEBUG: Code 0 at U/<JJR-nP{])'Nhan/sw:213130743
001003:0020 DEBUG: Code 139419 at U/<JJR-nP{])'Nhan/sw:29393332
001003:0020 DEBUG: Code 0 at \`UYGfS4/Kui8Q7Rm'$cX:29398622
005003:0000 Failed to save title 0 to file /Users/kimbarry/Movies/Live_and_Let_Die/Live_and_Let_Die_t00.mkv
005004:0080 0 titles saved, 1 failed
Thx Kim
kimerleighbarry@gmail.com
Re: Copy complete. 0 titles saved, 1 failed.
Post by Woodstock » Fri Nov 15, 2013 12:50 am
Your drive cannot read part of the disk. There is either a flaw in the disk, a scratch or smudge that cannot be read through, or the drive has a problem.
First step is cleaning the disk. Scratches do not have to be very visible to cause read problems. I've had them occur when a disk pops off the holder in shipping, and the plastic-on-plastic is just enough to cause a read problem. Waxing the disk takes care of that most of the time, but returning a defective disk for replacement is still a possibility.
Is the drive a bus-powered USB type? Verify that it has sufficient power, although the failure messages for this problem usually don't report as a medium error.
