makemkv 1.8.6 compilaton fails on Fedora 18/19/20
MartinKG
#1 Post by MartinKG » Tue Nov 12, 2013 8:54 am
HI,
tried to compile makemk 1.8.6 von Fedora 20, but this fails with the following error messages:
gcc -Os -D_GNU_SOURCE -D_linux_ -D_REENTRANT -shared -Wl,-z,defs -oout/libmakemkv.so.1.full -Ilibebml/inc -DEBML_NO_READ -DEBML_STRICT_API -Ilibmatroska/inc \
-Ilibmakemkv/inc -Isstring/inc -Imakemkvgui/inc -Ilibabi/inc -Ilibffabi/inc \
libebml/src/EbmlBinary.cpp libebml/src/EbmlContexts.cpp libebml/src/EbmlCrc32.cpp libebml/src/EbmlDate.cpp libebml/src/EbmlDummy.cpp libebml/src/EbmlElement.cpp libebml/src/EbmlFloat.cpp libebml/src/EbmlHead.cpp libebml/src/EbmlMaster.cpp libebml/src/EbmlSInteger.cpp libebml/src/EbmlString.cpp libebml/src/EbmlSubHead.cpp libebml/src/EbmlUInteger.cpp libebml/src/EbmlUnicodeString.cpp libebml/src/EbmlVersion.cpp libebml/src/EbmlVoid.cpp libebml/src/IOCallback.cpp libebml/src/MemIOCallback.cpp libmatroska/src/FileKax.cpp libmatroska/src/KaxAttached.cpp libmatroska/src/KaxAttachments.cpp libmatroska/src/KaxBlock.cpp libmatroska/src/KaxBlockData.cpp libmatroska/src/KaxChapters.cpp libmatroska/src/KaxCluster.cpp libmatroska/src/KaxClusterData.cpp libmatroska/src/KaxContentEncoding.cpp libmatroska/src/KaxContexts.cpp libmatroska/src/KaxCues.cpp libmatroska/src/KaxCuesData.cpp libmatroska/src/KaxInfo.cpp libmatroska/src/KaxInfoData.cpp libmatroska/src/KaxSeekHead.cpp libmatroska/src/KaxSegment.cpp libmatroska/src/KaxTag.cpp libmatroska/src/KaxTags.cpp libmatroska/src/KaxTrackAudio.cpp libmatroska/src/KaxTrackEntryData.cpp libmatroska/src/KaxTracks.cpp libmatroska/src/KaxTrackVideo.cpp libmatroska/src/KaxVersion.cpp libmakemkv/src/ebmlwrite.cpp libmakemkv/src/libmkv.cpp libmakemkv/src/version.cpp libmakemkv/src/world.cpp sstring/src/sstring.cpp \
libabi/src/ossl_aes.c libabi/src/ossl_sha.c libabi/src/ossl_ec.c libabi/src/zlib.c libabi/src/xpat.c libabi/pssl/ec_key.c libabi/pssl/ec_lib.c libabi/pssl/ec_cvt.c libabi/pssl/ec_mult.c libabi/pssl/ecp_mont.c libabi/pssl/ecp_smpl.c libabi/pssl/ecs_ossl.c libabi/pssl/ecs_sign.c libabi/pssl/ecs_vrf.c libabi/src/httplinux.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.c makemkvgui/src/spawn_posix.cpp libffabi/src/ffabi.c libffabi/src/mlp.c libffabi/src/log.c libffabi/src/audio_convert.c \
-DHAVE_BUILDINFO_H -Itmp \
-fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -lavcodec -lavutil -lm
libffabi/src/ffabi.c:22:32: fatal error: libavcodec/avcodec.h: No such file or directory
#include <libavcodec/avcodec.h>
compilation terminated.
libffabi/src/mlp.c:24:27: fatal error: libavutil/crc.h: No such file or directory
#include <libavutil/crc.h>
libffabi/src/log.c:29:27: fatal error: libavutil/log.h: No such file or directory
#include <libavutil/log.h>
libffabi/src/audio_convert.c:26:30: fatal error: libavutil/common.h: No such file or directory
#include <libavutil/common.h>
make: *** [out/libmakemkv.so.1.full] Error 1
further infos:
the package ffmpeg-devel is already installed
rpm -ql ffmpeg-devel |grep avcodec.h
/usr/include/ffmpeg/libavcodec/avcodec.h
/usr/include/ffmpeg/libavfilter/avcodec.h
but in the revision history it is mentioned
MakeMKV no longer uses external ffmpeg binary
any help ?
Martin
belegdol
Re: makemkv 1.8.6 compilaton fails on Fedora 18/19/20
#2 Post by belegdol » Tue Nov 12, 2013 9:15 pm
It will only build on Fedora 20 due to ffmpeg requirements. To make it build, you need to change
LIBFFABI_INC=-Ilibffabi/inc
to
LIBFFABI_INC=-Ilibffabi/inc -I/usr/include/ffmpeg
in the makefile.common
MartinKG
#3 Post by MartinKG » Wed Nov 13, 2013 8:34 am
thanks, that works only for Fedora 20, because of ffmpeg 2.x !
makefile.common-fedora.diff
--- makemkv-1.8.6/makemkv-oss-1.8.6/makefile.common.orig	2013-11-11 01:27:04.000000000 +0100
+++ makemkv-1.8.6/makemkv-oss-1.8.6/makefile.common	2013-11-13 09:20:58.585032750 +0100
@@ -40,7 +40,7 @@
 LIBABI_SRC_LINUX=libabi/src/httplinux.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.c makemkvgui/src/spawn_posix.cpp
-LIBFFABI_INC=-Ilibffabi/inc
+LIBFFABI_INC=-Ilibffabi/inc -I/usr/include/ffmpeg
 LIBFFABI_SRC=libffabi/src/ffabi.c libffabi/src/mlp.c libffabi/src/log.c libffabi/src/audio_convert.c
crowfax
#4 Post by crowfax » Wed Nov 13, 2013 4:17 pm
I made the changes suggested but I'm getting this error (Fedora 19)
matthew@optiplex990 makemkv-oss-1.8.6$ make -f makefile.linux
mkdir -p out
-Ilibmakemkv/inc -Isstring/inc -Imakemkvgui/inc -Ilibabi/inc -Ilibffabi/inc -I/usr/include/ffmpeg \
Any help?
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
belegdol
#5 Post by belegdol » Wed Nov 13, 2013 4:49 pm
You probably don't have ffmpeg-devel installed. In any case, ffmpeg in Fedora 19 is too old (1.2.4).
crowfax
#6 Post by crowfax » Wed Nov 13, 2013 5:27 pm
blergh, installed the devel package and now I have a new error
mkdir -p out
libffabi/src/ffabi.c: In function ‘ffm_audio_decode_init’:
libffabi/src/ffabi.c:166:15: error: ‘AVCodecContext’ has no member named ‘refcounted_frames’
     ctx->avctx->refcounted_frames = 1;
libffabi/src/ffabi.c: In function ‘ffm_audio_encode_init’:
libffabi/src/ffabi.c:321:15: error: ‘AVCodecContext’ has no member named ‘refcounted_frames’
Doesn't someone out there maintain a repo for ffmpeg for fedora?
belegdol
#7 Post by belegdol » Wed Nov 13, 2013 5:29 pm
I told you it will not work, tried it myself. I am one of the people maintaining ffmpeg for Fedora. We do not update ffmpeg after release due to multitude of dependencies. Fedora 20 will be out in a month, and it sports ffmpeg-2.1.0 which does work with makemkv-1.8.6.
#8 Post by mike admin » Fri Nov 15, 2013 7:48 am
MakeMKV SHOULD work with ffmpeg 1.2 . It does NOT require refcounted_frames - the fact that compilation fails is a bug in MakeMKV. Please see http://www.makemkv.com/forum2/viewtopic.php?f=3&t=7215
MartinKG
#9 Post by MartinKG » Fri Nov 15, 2013 9:52 am
i tried the following patch on fedora 19, but it fails with the message:
cat -v ffmpeg-fedora.diff
--- makemkv-1.8.6/makemkv-oss-1.8.6/libffabi/src/ffabi.c.orig	2013-11-15 09:51:07.817186784 +0100
+++ makemkv-1.8.6/makemkv-oss-1.8.6/libffabi/src/ffabi.c	2013-11-15 09:52:13.002189931 +0100
@@ -162,9 +162,6 @@
     ctx->avctx->opaque = logctx;
     ctx->avctx->time_base.num = 1;
     ctx->avctx->time_base.den = time_base;
-#if (LIBAVCODEC_VERSION_MAJOR >= 54)
-    ctx->avctx->refcounted_frames = 1;
-#endif
     if (CodecData) {
         ctx->avctx->extradata = (uint8_t*) CodecData;
@@ -317,9 +314,6 @@
         ffm_audio_encode_close(ctx);
         return NULL;
-#endif
gcc -Os -D_GNU_SOURCE -D_linux_ -oout/makemkv.full -Imakemkvgui/inc -Ilibmakemkv/inc -Isstring/inc -Ilibdriveio/inc -Ilibabi/inc \
makemkvgui/src/aboutbox.cpp makemkvgui/src/client.cpp makemkvgui/src/dirselectbox.cpp makemkvgui/src/logic.cpp makemkvgui/src/logtext.cpp makemkvgui/src/main.cpp makemkvgui/src/nativefiledialog.cpp makemkvgui/src/mainwnd.cpp makemkvgui/src/marshall.cpp makemkvgui/src/progress.cpp makemkvgui/src/scsiinfo.cpp makemkvgui/src/settingdlg.cpp makemkvgui/src/uisync.cpp makemkvgui/src/viteminfo.cpp makemkvgui/src/margui.cpp makemkvgui/src/backupdlg.cpp makemkvgui/src/lstring.cpp makemkvgui/src/notify.cpp makemkvgui/src/str/en_utf16.cpp makemkvgui/src/image.cpp makemkvgui/src/abutton.cpp makemkvgui/src/lineeditk.cpp makemkvgui/src/api_posix.cpp makemkvgui/src/api_linux.cpp makemkvgui/src/sem_posix.cpp makemkvgui/src/spawn_posix.cpp makemkvgui/src/logic_posix.cpp makemkvgui/src/notify_linux.cpp makemkvgui/src/image_linux.cpp tmp/image_data.o tmp/moc_mainwnd.cpp tmp/moc_logtext.cpp tmp/moc_dirselectbox.cpp tmp/moc_aboutbox.cpp tmp/moc_settingdlg.cpp tmp/moc_backupdlg.cpp tmp/moc_lineeditk.cpp sstring/src/sstring.cpp libdriveio/src/srlist.cpp \
-I/usr/include/qt4 -I/usr/lib/qt4/include -L/usr/lib/qt4 -L/usr/lib/qt4/lib -lc -lstdc++ \
-lQtGui -lQtCore -lQtDBus -lpthread -lz -lrt
objcopy --strip-all --strip-debug --strip-unneeded --discard-all out/libdriveio.so.0.full out/libdriveio.so.0
objcopy --strip-all --strip-debug --strip-unneeded --discard-all out/libmmbd.so.0.full out/libmmbd.so.0
/tmp/ccTxIVBG.o: In function `ffm_audio_decode_close':
ffabi.c:(.text+0x137): undefined reference to `av_frame_unref'
/tmp/ccTxIVBG.o: In function `ffm_audio_decode_put_data':
ffabi.c:(.text+0x2dd): undefined reference to `av_frame_unref'
/tmp/ccTxIVBG.o: In function `ffm_audio_encode_close':
ffabi.c:(.text+0x425): undefined reference to `av_frame_unref'
/tmp/ccTxIVBG.o: In function `ffm_audio_encode_put_frame':
ffabi.c:(.text+0x61f): undefined reference to `av_frame_unref'
collect2: error: ld returned 1 exit status
make: *** Waiting for unfinished jobs....
furhter informations
rpm -qa |grep ffmpeg-devel
ffmpeg-devel-1.2.4-2.fc19.x86_64
cat -v /usr/include/ffmpeg/libavcodec/version.h
 * This file is part of FFmpeg.
 * FFmpeg is free software; you can redistribute it and/or
 * modify it under the terms of the GNU Lesser General Public
 * License as published by the Free Software Foundation; either
 * version 2.1 of the License, or (at your option) any later version.
 * FFmpeg is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 * Lesser General Public License for more details.
 * You should have received a copy of the GNU Lesser General Public
 * License along with FFmpeg; if not, write to the Free Software
 * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
#ifndef AVCODEC_VERSION_H
#define AVCODEC_VERSION_H
 * @file
 * @ingroup libavc
 * Libavcodec version macros.
#include "libavutil/avutil.h"
#define LIBAVCODEC_VERSION_MAJOR 54
#define LIBAVCODEC_VERSION_MINOR 92
#define LIBAVCODEC_VERSION_MICRO 100
#define LIBAVCODEC_VERSION_INT  AV_VERSION_INT(LIBAVCODEC_VERSION_MAJOR, \
                                               LIBAVCODEC_VERSION_MINOR, \
                                               LIBAVCODEC_VERSION_MICRO)
#define LIBAVCODEC_VERSION      AV_VERSION(LIBAVCODEC_VERSION_MAJOR,    \
#define LIBAVCODEC_BUILD        LIBAVCODEC_VERSION_INT
#define LIBAVCODEC_IDENT        "Lavc" AV_STRINGIFY(LIBAVCODEC_VERSION)
 * FF_API_* defines may be placed below to indicate public API that will be
 * dropped at a future version bump. The defines themselves are not part of
 * the public API and may change, break or disappear at any time.
#ifndef FF_API_REQUEST_CHANNELS
#define FF_API_REQUEST_CHANNELS (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_ALLOC_CONTEXT
#define FF_API_ALLOC_CONTEXT    (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_AVCODEC_OPEN
#define FF_API_AVCODEC_OPEN     (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_OLD_DECODE_AUDIO
#define FF_API_OLD_DECODE_AUDIO (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_OLD_TIMECODE
#define FF_API_OLD_TIMECODE (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_OLD_ENCODE_AUDIO
#define FF_API_OLD_ENCODE_AUDIO (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_OLD_ENCODE_VIDEO
#define FF_API_OLD_ENCODE_VIDEO (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_MPV_GLOBAL_OPTS
#define FF_API_MPV_GLOBAL_OPTS  (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_COLOR_TABLE_ID
#define FF_API_COLOR_TABLE_ID   (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_INTER_THRESHOLD
#define FF_API_INTER_THRESHOLD  (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_SUB_ID
#define FF_API_SUB_ID           (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_DSP_MASK
#define FF_API_DSP_MASK         (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_FIND_BEST_PIX_FMT
#define FF_API_FIND_BEST_PIX_FMT (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_CODEC_ID
#define FF_API_CODEC_ID          (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_VDA_ASYNC
#define FF_API_VDA_ASYNC         (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_AVCODEC_RESAMPLE
#define FF_API_AVCODEC_RESAMPLE  (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_LIBMPEG2
#define FF_API_LIBMPEG2          (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_MMI
#define FF_API_MMI               (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_IDCT
#define FF_API_IDCT              (LIBAVCODEC_VERSION_MAJOR < 55)
#endif
#ifndef FF_API_DEINTERLACE
#define FF_API_DEINTERLACE       (LIBAVCODEC_VERSION_MAJOR < 56)
#endif
#endif /* AVCODEC_VERSION_H */
