version 1.86
Murray
version 1.86
Post by Murray » Wed Nov 13, 2013 7:37 am
I am a paid up member but I cant download the new version. Every time I try it always reverts back to the old one, why is this?
Re: version 1.86
Post by Woodstock » Wed Nov 13, 2013 10:33 pm
When you try to install, do you make sure there are no copies running?
If any copy is running, the new version cannot be copied into place. The install program does not always tell you that it could not do the copy, though!
Re: version 1.86
Post by mike admin » Thu Nov 21, 2013 7:10 am
Can you uninstall the previous version, reboot, and then install a new one? What OS are you using? How do you check the version?
