Does not work after upgrading to makemkv-1.8.6 & Fedora 20
belegdol
Post by belegdol »
I have updated my system from Fedora 19 to Fedora 20 Beta in order to be able to install makemkv-1.8.6. Unfortunately, the set-up no longer works after this operation, even though I am trying exactly the same discs as yesterday. Any ideas what might have gone wrong?
$ LANG=C MMBD_TRACE=1 bd_info /dev/sr0
MMBD: MakeMKV v1.8.6 linux(x64-release) started
MMBD: Debug logging enabled, log will be saved as /tmp/MakeMKV-0x2890-1.tmp
MMBD: Using direct disc access mode
MMBD: DEBUG: Code 0 at 968:/d {L.@.y[@Vbv:121263843
MMBD: DEBUG: Code 0 at 968:/d {L.@.y[@Vbv:121262394
MMBD: DEBUG: Code 1 at 968:/d {L.@.y[@Vbv:121262394
MMBD: DEBUG: Code 2 at 968:/d {L.@.y[@Vbv:121262394
MMBD: DEBUG: Code 3 at 968:/d {L.@.y[@Vbv:121262394
MMBD: DEBUG: Code 4 at 968:/d {L.@.y[@Vbv:121262394
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..003CD1E1D3C5D8FC322BF76E2DE607C50F0 to device 'SG:dev_11:0'
MMBD: DEBUG: Code 0 at 2>b{]PuU/Z=aoBTpw:213130743
MMBD: DEBUG: Code 0 at 968:/d {L.@.y[@Vbv:29395034
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..021A58D518FB0BE75E9028F87E4EB881F63 to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..009E73DD3451510F7C919893BFF93F54AB1 to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04A73A45245B44BD7F4D01958952A12F460 to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D5239DCA8B661F4E4F7DACBC620BF6105A to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:0'
MMBD: DEBUG: Code 0 at 968:/d {L.@.y[@Vbv:121264303
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0400509287EA7052989B14C28AA8FFABE67 to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FC6B3D2CE84175338F73913BC0491E8C4F to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C88A7791CA4C276087B611627B85378B1C to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..036C8DE0E7560E23CDB7EF47A9E63E9808F to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FE78B2AAEDA6A4615576F6F68C4833D938 to device 'SG:dev_11:0'
MMBD: Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
MMBD: Highest AACS version is v36 , MKB saved as /home/julas/.MakeMKV/MKB_v36_THE_BIG_BANG_THEORY_S6_D1.tgz
MMBD: The volume key is unknown for this disc - video can't be decrypted
MMBD: DEBUG: Code 0 at a2o=[@f6V$|=C"X1:29395379
MMBD: DEBUG: Code 0 at a2o=[@f6V$|=C"X1:29396943
MMBD: Failed to open disc
libbluray/bluray.c:794: aacs_open() failed!
BluRay detected : yes
First Play supported: no
Top menu supported : yes
HDMV titles : 18
BD-J titles : 2
UNSUPPORTED titles : 2
AACS detected : yes
libaacs detected : yes
Disc ID : 0000000000000000000000000000000000000000
AACS MKB version : 0
AACS handled : no
(corrupted BluRay disc)
BD+ detected : no
Disc library metadata:
Metadata file : bdmt_eng.xml
Language : eng
Disc name : The Big Bang Theory Season 6 Disc 1
Alternative : <undefined>
Disc # : <undefined>/<undefined>
TOC count : 0
Thumbnail count : 2
./Big_Bang_metadata416.jpg 416x240
./Big_Bang_metadata640.jpg 640x360
Re: Does not work after upgrading to makemkv-1.8.6 & Fedora
Post by mike admin »
belegdol wrote:I have updated my system from Fedora 19 to Fedora 20 Beta in order to be able to install makemkv-1.8.6. Unfortunately, the set-up no longer works after this operation, even though I am trying exactly the same discs as yesterday. Any ideas what might have gone wrong?
Have you inserted any recently-released discs into the drive before it stopped working?
belegdol
Post by belegdol »
I don't have any new ones. The ones I was inserting were the big bang theory season 7 and star trek tng season 2, both of which worked before the upgrade.
belegdol
Post by belegdol »
Is there any chance you could send me makemkv-1.8.5? This way I could check if it is the system upgrade which hosed the setup.
ylood
Post by ylood »
Old releases are available here : http://www.makemkv.com/download/old/
belegdol
Post by belegdol »
Downgrading to 1.8.5 does not help unfortunately. Should I post the MKB_v*.tgz files somewhere?
file/dl_posix.c:101: dlsym(0x2226c80, 'aacs_get_device_binding_id') failed: /lib64/libaacs.so.0: undefined symbol: aacs_get_device_binding_id
MMBD: MakeMKV v1.8.5 linux(x64-release) started
MMBD: Debug logging enabled, log will be saved as /tmp/MakeMKV-0x3a0a-1.tmp
MMBD: The new version 1.8.6 is available for download at /download
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COMMAND SEQUENCE ERROR' occurred while issuing SCSI command A40..002007401 to device 'SG:dev_11:0'
MMBD: DEBUG: Code 0 at pzA|qF7Fm9Nn"..]%(:29395011
MMBD: DEBUG: Code 0 at pzA|qF7Fm9Nn"..]%(:121262394
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COMMAND SEQUENCE ERROR' occurred while issuing SCSI command A40..002005442 to device 'SG:dev_11:0'
MMBD: DEBUG: Code 0 at pzA|qF7Fm9Nn"..]%(:213131617
MMBD: DEBUG: Code 1 at pzA|qF7Fm9Nn"..]%(:121262394
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COMMAND SEQUENCE ERROR' occurred while issuing SCSI command A40..002005402 to device 'SG:dev_11:0'
MMBD: DEBUG: Code 2 at pzA|qF7Fm9Nn"..]%(:121262394
MMBD: DEBUG: Code 3 at pzA|qF7Fm9Nn"..]%(:121262394
MMBD: DEBUG: Code 4 at pzA|qF7Fm9Nn"..]%(:121262394
MMBD: DEBUG: Code 0 at pzA|qF7Fm9Nn"..]%(:121263843
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0351A46F331B49CF62A03DD855CDECDF41C to device 'SG:dev_11:0'
MMBD: DEBUG: Code 0 at {#S$#DC#3{83%h$Yi:213130743
MMBD: DEBUG: Code 0 at pzA|qF7Fm9Nn"..]%(:29395034
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08197352A446371A3CD04C05212E30EE6DF to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B314648835946AFA84B21D54E909B709EE to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..026DBB762059BF95B2588076145A9FDB81D to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..033D2A5D11F2C4DAF8863B91BCFA7A17EC9 to device 'SG:dev_11:0'
MMBD: DEBUG: Code 0 at pzA|qF7Fm9Nn"..]%(:121264303
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COMMAND SEQUENCE ERROR' occurred while issuing SCSI command A30..00200740100720..039E1F7BCBEFE8EFE11F0CEB5EF3C17FADD to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002440 to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0290891B71F12165B8C529311F32AD4236F to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CAA6E17AC29D7CDFCA30891694C4A07725 to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FE5D11709F0B4C2644DE3BB3F24A8C67 to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08B8B74B451A073EB52D9FB72C171D72CF8 to device 'SG:dev_11:0'
MMBD: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BEF0C244FCE4EA0298BCE416DA856F8AEE to device 'SG:dev_11:0'
MMBD: DEBUG: Code 0 at ]J2,2'1~> 3.Cjyz:121263544
MMBD: DEBUG: Code 0 at ]J2,2'1~> 3.Cjyz:121265223
HDMV titles : 18
BD-J titles : 2
AACS detected : yes
AACS handled : no
BD+ detected : no
Language : eng
Disc name : The Big Bang Theory Season 6 Disc 2
TOC count : 0
Thumbnail count : 2
unxfrek
Post by unxfrek »
I can confirm the exact same as belegdol, everything worked great in Fedora 19 MakeMKV 1.8.5. When updated to Fedora 20 MakeMKV 1.8.6 I can't access any of the blurays, same error as belegdol.
Shortened version of the error:
file/libaacs.c:94: libaacs not found!
First Play supported: yes
HDMV titles : 3
BD-J titles : 78
UNSUPPORTED titles : 78
AACS detected : yes
libaacs detected : no
BD+ detected : no
Language : eng
Disc name : Star Trek Into Darkness
Disc # : 1/1
TOC count : 1
Title 1: Star Trek Into Darkness
Thumbnail count : 2
Let me know if I can provide any further info to help debug.
pbuelow
Post by pbuelow »
I am having the same issue. Nearly the same errors. It worked forever on Fedoras up to 19, but with 20, it simply doesn't. Has anyone had time to look into this? Is there something I can help with?
EDIT: I found the post about AACS in Fedora at the top, and that seems to have resolved the issue for me. Thank you to those who found the issue.
