DVD Menu Shows 3 But MKV Only Makes 2
JimMacMillan
Post by JimMacMillan » Sun Nov 03, 2013 10:40 pm
Hello Everyone,
I'm rendering MKV files from a 70's television series entitled Banacek TVDB Link
On Season 2 Disc 2 the DVD menu shows 3 episodes. They all play on my DVD player but MAKEMKV is only converting 2 of them.
Any thoughts?
Thanks In Advance :)
Jim
JimMacMillan
UPDATE - DVD Menu Shows 3 But MKV Only Makes 2
Post by JimMacMillan » Wed Nov 06, 2013 10:36 pm
Attached is the MakeMKV_log.txt and below is a screenshot of the files in the VIDEO_TS Folder.
As you can see in the screenshot MAKEMKV should be rendering 3 episodes but the log appears to only show 2 for some reason.
MakeMKV_log.txt
MakeMKV_log
(933 Bytes) Downloaded 434 times
JimMacMillan
Re: DVD Menu Shows 3 But MKV Only Makes 2
Post by JimMacMillan » Tue Nov 12, 2013 7:07 am
Does anyone have any thoughts on this? I D/L'd and installed the new version today and it's still not working correctly (at least on this particular DVD).
JimMacMillan
Post by JimMacMillan » Sun Nov 24, 2013 7:21 am
Okay I D/L'd and installed "DVD Decrypter" and ran the DVD through it. Then I ran the decrypted files through MAKEMKV.
I'm still not having any luck with this. I could really use some direction. I don't mind paying for the program if that is what it takes.
Jim
Chetwood
Post by Chetwood » Sun Nov 24, 2013 9:17 am
Apparently the authoring confused MakeMKV so it doesn't see all three eps. What happens when you reauthor the 3eps in DVD Shrink and the open this ISO in MakeMKV?
Wasabi
Post by Wasabi » Tue Dec 10, 2013 11:39 pm
JimMacMillan wrote:Okay I D/L'd and installed "DVD Decrypter" and ran the DVD through it. Then I ran the decrypted files through MAKEMKV.
Jim
Until you get this sorted in MakeMKV, you can use MKVtoolnix to remux the decrypted VOBs into an MKV container.
