DVD Menu Shows 3 But MKV Only Makes 2
JimMacMillan
Post by JimMacMillan »
Hello Everyone,
I'm rendering MKV files from a 70's television series entitled Banacek TVDB Link
On Season 2 Disc 2 the DVD menu shows 3 episodes. They all play on my DVD player but MAKEMKV is only converting 2 of them.
Any thoughts?
Thanks In Advance :)
Jim
JimMacMillan
UPDATE - DVD Menu Shows 3 But MKV Only Makes 2
Attached is the MakeMKV_log.txt and below is a screenshot of the files in the VIDEO_TS Folder.
As you can see in the screenshot MAKEMKV should be rendering 3 episodes but the log appears to only show 2 for some reason.
JimMacMillan
Re: DVD Menu Shows 3 But MKV Only Makes 2
Does anyone have any thoughts on this? I D/L'd and installed the new version today and it's still not working correctly (at least on this particular DVD).
JimMacMillan
Okay I D/L'd and installed "DVD Decrypter" and ran the DVD through it. Then I ran the decrypted files through MAKEMKV.
I'm still not having any luck with this. I could really use some direction. I don't mind paying for the program if that is what it takes.
Jim
Chetwood
Post by Chetwood »
Apparently the authoring confused MakeMKV so it doesn't see all three eps. What happens when you reauthor the 3eps in DVD Shrink and the open this ISO in MakeMKV?
Wasabi
Post by Wasabi »
JimMacMillan wrote:Okay I D/L'd and installed "DVD Decrypter" and ran the DVD through it. Then I ran the decrypted files through MAKEMKV.
Jim
Until you get this sorted in MakeMKV, you can use MKVtoolnix to remux the decrypted VOBs into an MKV container.
