TV show discs
dbvanhorn
TV show discs
Post by dbvanhorn »
I have a number of TV show disks that I ripped to .ISO files long ago.
When I play them as .iso files, they work as I expect, but when I run them through MakeMKV I get only one episode. I'm sure this is something simple, but I don't know what it is.
How do I set up MakeMKV (running behind MakeMKV Batch Converter) to get all the episodes?
Gadgetman!
Re: TV show discs
Post by Gadgetman! »
Are you certain that the DVDs had the episodes coded as separate blocks?
What does it look like if you try the original DVD?
Which series?
Mac Mini, 2005 with superdrive, 2GB RAM, 80GB SSD, Core2Duo 2.16GHz CPU...
2 x LG USB DVD-drives and 'old spiteful' an IDE-based DVD-reader from a desktop connected to the internals of an old FW-HDD.
Writes Sci-fi:
http://www.planetfurry.com/~anthony/
