Fatal Error occurred, programm will now exit
shemsha
Using Ubuntu 9.10.
Installed according to
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224
Once I try and run makemkv, I get this.
Any ideas?
I'm a beginner in lunix...
Any ideas?
driver140771
Re: Fatal Error occurred, programm will now exit
I think, we have the same problem.
http://www.makemkv.com/forum2/viewtopic.php?f=3&t=944
Please, look to
/var/log/message
for errors.
Please, look to
/var/log/message
for errors.
shemsha
Correct,
in /var/log/messages
I see
[ 3587.315895] makemkvcon[2050]: segfault at 0 ip 08227360 sp 982f7ed8 error 4 in makemkvcon[8048000+3c3000]
I see
skittle
I get the same
starting makemkvcon from dash works though still arrives at segfault
Feb 2 17:42:03 Skittle-PC kernel: [ 5810.030953] makemkvcon[6444]: segfault at 0 ip 000000000060398e sp 00007fe20cbc3ba0 error 4 in makemkvcon[400000+48c000]
- Contact:
is this in 1.4.11 or 1.4.12 ? can you provide the core dump? please send it to support@makemkv.com in case it contains any private information.
shemsha
Thanks,
I am kind of new, how do I get the core dump? The version is the newest one, 1.4.12
driver140771
driver140771
i have only this information:
vdr@vdr-pc:~$ sudo /usr/bin/makemkvcon info
001005:0000 MakeMKV v1.4.12 beta linux(x64-release) started
Segmentation fault
vdr@vdr-pc:~$ -
JackieBrown
Same error on Debian 64 using 1.4.12
Going back to 1.4.11 fixed the problem
shemsha
1.4.11 worked for me as well. Thanks.
By the way, in the future, how do I remove makemkv if I want to?
driver140771
I don't have the Vesion 1.4.11
I also hope the Version 1.4.12 (13) is working soon.
Thank's
Thank's
shemsha
skittle
shemsha:
mikeadmin: I have created a coredump for you, and sent it to support@makemkv.com
Others: to make a coredump, to then run the program.
sudo rm /usr/bin/makemkv & rm /usr/bin/makemkvconOthers: to make a coredump, to
ulimit -c unlimited-
JackieBrown
Mike - I am linking 1.4.11. If you need me to remove it, just let me know.
I made no edits to the tars you originally uploaded
http://www.mediafire.com/file/uyzld5ymm ... bin.tar.gz
http://www.mediafire.com/file/dmtufztto ... oss.tar.gz
phantasm4489
I tried to install this program last night and had the same problem with 1.4.12. (segmentation fault on startup)
I downloaded 1.4.11 instead (by altering the urls in the official link to 1.4.12) and installed that and it works fine.
