Weeds - Complete Collection - Season 3 Disc 2
MediaLibrary
Post by MediaLibrary » Sun Nov 10, 2013 6:03 pm
For some reason the tracks are duplicated on Season 3 Disc 2 only, so "13, 13", "14, 14", etc..
I checked the standalone version of Season 3 and it is identical. Is there a way I can edit the MPLS to remove the duplicate item?
Re: Weeds - Complete Collection - Season 3 Disc 2
Post by Woodstock » Sun Nov 10, 2013 9:02 pm
Not much to work from... Do you have debugging turned on? (signature link explains how) Are you doing a "backup" or ripping to MKV files?
Post by mike admin » Mon Nov 11, 2013 7:19 am
MediaLibrary wrote:For some reason the tracks are duplicated on Season 3 Disc 2 only, so "13, 13", "14, 14", etc..
Yes, make a full dic backup and just delete all MPLS files. MakeMKV would then open M2TS files directly. You'll lose chapter information, but that's it.
gabeen
Post by gabeen » Thu Dec 31, 2015 2:09 am
Any update on this? I just got Weeds Season 3 myself, and on disc 2 it maps all the episodes twice in the same title as seen here:
The backup trick works fine though, however theres no chapters (which I like).
So is it possible we could get a fix for this? I've turned on debugging and attached it here.
Disc Information
Label: WEEDSS3DISK1
Timestamp: 2008-05-11 12:27:23
Data capacity: 43.91 Gb
Disc type: BD-ROM
Number of layers: 2
MakeMKV_log_WeedsS3D2.txt
(3.6 KiB) Downloaded 822 times
ndjamena
Post by ndjamena » Thu Dec 31, 2015 2:22 am
If you've done a full backup, use EAC3To on it.
How are the chapters done? Are they duplicated too?
It doesn't matter, use EAC3To on the mpls files to extract the chapters, delete the extra chapters if they're there, then add them to the file using MKVToolNix.
gabeen
Post by gabeen » Thu Dec 31, 2015 3:29 am
ndjamena wrote:If you've done a full backup, use EAC3To on it.
Yep, the chapters are duplicated too.
Hopefully Mike can fix this in MakeMKV though :)
gabeen
Post by gabeen » Sat Jan 16, 2016 8:02 pm
This is now fixed in MakeMKV v1.9.9 (17.1.2016).
