OS error - (ipc/send) invalid destination port
yellowsnow
Post by yellowsnow » Mon Nov 11, 2013 5:15 am
I sporadically get blu-rays to convert, but most of them give the error above, even new ones with no visible blemishes. From searching the forums, it looks like it could have to do with the drive being underpowered, but this drive IS NOT powered over USB (it has a transformer to plug into the wall).
Is this just a bad drive or maybe something else?
MakeMKV_log.txt
Debug Log
(23.66 KiB) Downloaded 434 times
Re: OS error - (ipc/send) invalid destination port
Post by mike admin » Mon Nov 11, 2013 7:13 am
This does look like bad drive or disc. Can you copy the offending file in Finder?
yellowsnow
Post by yellowsnow » Wed Nov 13, 2013 5:59 am
In case there's anything new, here's another attempt using v1.8.6 and DASPI 1.4.
Trying to copy the BDMV file from the disc to my desktop fails after about 13 GB: "The Finder can’t complete the operation because some data in “” can’t be read or written. (Error code -36)".
MakeMKV_log.txt
Log
(14.74 KiB) Downloaded 436 times
Post by mike admin » Wed Nov 13, 2013 9:40 am
It certainly is a bad disc or drive, or both.
yellowsnow
Post by yellowsnow » Tue Dec 17, 2013 1:15 am
I was luckily able to get the drive replaced under warranty and the new drive (Pioneer this time) works fine every time. Thanks for the help.
