AVCHD files with metadata support
Starting from version 1.4.12 MakeMKV can open AVCHD files from any AVCHD-compatible digital camcorder. MakeMKV will preserve clip metadata and will automatically name output files by name and date. This feature is freeware. If you have an AVCHD camcorder please give it a try. Please post in this thread if MakeMKV doesn't recognize clip date/time or camcorder model or if this feature worked for you.
nascar
Re: AVCHD files with metadata support
I tried MakeMKV 1.4.12 beta with a Sony HDR-CX7 camcorder by navigating to G:\AVCHD\BDMV\INDEX.BDM on the memory stick.
I had to reduce the minimum title time to 30 seconds because of the short length of the clips
The filename title did not include the date/time from the clip, but the results look good to me. Here's the MediaInfo output for one of the files on the memory stick:
Great product! An easy way to convert clips to MKV.
Edit 03-08-2010: Version 1.5.0 beta detects the metadata from the AVCHD file and names the file by date and time.
However, MediaInfo reports the display aspect ratio as 4:3 not 16:9 as in the original file.
General
Complete name : D:\Videos\MakeMKV\title00.mkv
Format : Matroska
File size : 62.6 MiB
Duration : 34s 48ms
Overall bit rate : 15.4 Mbps
Encoded date : UTC 2010-02-04 01:51:22
Writing application : MakeMKV v1.4.12 beta win(x86-release)
Writing library : libmakemkv v1.4.12 beta (0.7.7/0.8.1) win(x86-release)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Muxing mode : Container profile=Unknown@4.0
Codec ID : V_MPEG4/ISO/AVC
Duration : 34s 0ms
Bit rate : 14.7 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.315
Stream size : 59.4 MiB (95%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 34s 48ms
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Video delay : -66ms
Stream size : 1.82 MiB (3%)
Title : 3/2+1
It shoud have recognized AVCHD source but apparently it didn't. MakeMKV ignores "minimum title length" when it recognizes AVCHD source.
Please do the following:
- format memory stick in your camcorder
- shoot 3 clips 1-3 seconds each
- copy all files from memory stick, compress with archiver of your choice and send to support@makemkv.com
mketech
I encountered this error so I've sent three 3-sec clips with the latest version of MakeMKV as requested.mike admin wrote:It shoud have recognized AVCHD source but apparently it didn't. MakeMKV ignores "minimum title length" when it recognizes AVCHD source.
Please do the following:The whole point of AVCHD processing is so you get files named by timestamp rather than title0.mkv .
Here's the info while processing:
MakeMKV v1.4.12 beta darwin(x86-release) started
Opening files on harddrive at /Volumes/Untitled/AVCHD/
AACS directory not present, assuming unencrypted disc
Failed to parse AVCHD metadata embedded by your camera, please report it on http://www.makemkv.com/forum
Title #00000.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
I used a Sony HDR-SR11 camcorder. I am using the feature to the embed the date and time stamp in the subtitles so I'm hopeful this information will be preserved. Thanks.
