Version checking
mrreload
Version checking
Post by mrreload »
I am using the command line makemkvcon within a program I created to automate ripping. I purchased MakeMKV and use a license key. Apparently the command line does not adhere to the same settings as the GUI.
Specifically version checking. The GUI will skip the check when I have "Allow contacting web server for updates" unchecked and I can use it. makemkvcon errors out with "This application version is too old"
I know there is an update slated for tomorrow but I just wanted the developers to be aware of this bug.
Unless there is a command line switch I am missing? I have been using MakeMKVcon this way for at least 2 years.
Re: Version checking
Post by mike admin »
The version 1.8.6 is out. Sorry for the delay.
