problem creating MVC 3D MKV
Everything related to Blu-ray 3D and 3D MKV files
Stu Pedasso
Post by Stu Pedasso »
Although creating MVC 3d MKVs has been generally reliable, I am having a problem with one title, the French version of Journey to the Center of the Earth (ISO).
Here is the bug report:
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 11707514880, attempting to work around
DEBUG: Code 0 at <:[}Wfm2Jp0@X.X_ML"I:29394574
DEBUG: Code 106 at <:[}Wfm2Jp0@X.X_ML"I:213132399
The source file '/BDMV/STREAM/00004.m2ts' is corrupt or invalid at offset 11707533312, attempting to work around
DEBUG: Code 0 at L],k^7>#Y\umoCQoq"},:29405039
DEBUG: Code 0 at aQz@ofj}|gB~qlTc:c}Y3:29398645
DEBUG: Code 0 at l6KejuZ!V)%}]/UfA:121263728
DEBUG: Code 0 at l6KejuZ!V)%}]/UfA:121263176
DEBUG: Code 0 at l6KejuZ!V)%}]/UfA:29393930
DEBUG: Code 0 at aQz@ofj}|gB~qlTc:c}Y3:29399013
AV synchronization issues were found in file 'D:/Voyage_au_centre_de_la_terre/Voyage_au_centre_de_la_terre_t00.mkv' (title #1)
AV sync issue in stream 0 at 0:42:17.117 : secondary stream video frame timecode differs by +41.705ms
Failed to save title 0 to file D:/Voyage_au_centre_de_la_terre/Voyage_au_centre_de_la_terre_t00.mkv
0 titles saved, 1 failed
Any ideas on how to get around these errors?
Re: problem creating MVC 3D MKV
Post by mike admin »
The video stream is corrupt. Firstly, please make a full disc backup with MakeMKV and see if any hashcheck errors show up. Then please produce a test dump per instructions at /onlinehelp/testdump.html
Stu Pedasso
Hi Mike,
I did a full disc backup and did not encounter any hashcheck errors. I sent you a link for the testdump.
Thanks for all of your help!
Stu
