This disc uses a newer version of AACS protection......
rmalay
Post by rmalay »
Recents disks:
The Right Stuff
White House Down
Grown Ups 2
After Earth
Vincent Price Collection
Is this just a warning or have the resulting MKV files been effected by this???
Re: This disc uses a newer version of AACS protection......
When you get this warning, there should be a link in the log to report the new version information to Mike. Please click on it to make the report.
rmalay
Post by rmalay »
Yes I've done that for all them - but this does not answer my question. Are the resulting MKV files affected by this or is this just a warning?
I've tested these disks on three different drives at home and one at work -- all produce the same message, but they also complete the MKV process.
Which makes me wonder if there are issues with these MKV files.
When it happened to me a couple of weeks ago, it did not affect the rips. The issue is if an AACS update invalidates the current MakeMKV key... in which case, "more errors will occur".
If MakeMKV said it saved the files, though, they should be good.
necrosis
Post by necrosis »
Can't speak for the others but I ran After Earth with no issues and no warnings. Make MKV 1.8.5.
