File size reduction
GeePee
File size reduction
#1 Post by GeePee » Sat Nov 02, 2013 9:30 pm
I had the impression that MakeMKV had the ability to reduce the file size of the original DVD/Blueray file to users need. Cannot find this function, so I presume I was wrong.
Anyone confirm or deny my impression?
Romansh
Re: File size reduction
#2 Post by Romansh » Sat Nov 02, 2013 11:08 pm
I can confirm that MakeMKV doesn't and has never supported re-encoding.
The only way to reduce the file size with it is removing streams you don't need/want (keeping only English audio tracks and removing the rest, for example).
GeePee
#3 Post by GeePee » Sun Nov 03, 2013 10:41 am
Thank you. That answers my question. On my first uses of MakeMKV it worked fine and I seem to remember that I did remove the un-necessary audio.
Gadgetman!
#4 Post by Gadgetman! » Mon Nov 04, 2013 10:17 pm
Removing audio streams won't really reduce the files all that much.
(We still do it, though)
Running HandBrake or a similar encoder, though...
With the default settings, HB will reduce the filesize to one fourth or less.
(Working on the Jeeves & Wooster TV series right now, and 2.2 GB files end up between 500 and 600MB. )
There are some exceptions, though, such as the old Charlie Chaplin B/W movies which doesn't really reduce all that much.
Mac Mini, 2005 with superdrive, 2GB RAM, 80GB SSD, Core2Duo 2.16GHz CPU...
2 x LG USB DVD-drives and 'old spiteful' an IDE-based DVD-reader from a desktop connected to the internals of an old FW-HDD.
Writes Sci-fi:
http://www.planetfurry.com/~anthony/
