Entourage - Doesn't see All Episodes
rpmccly
#1 Post by rpmccly » Thu Oct 06, 2011 2:03 am
Anyone know why you can't see all the episodes on an Entourage bluray? It only pulls up one? Anyone else had any trouble with the Entourage blurays?
kully
Re: Entourage - Doesn't see All Episodes
#2 Post by kully » Fri Nov 01, 2013 12:25 pm
Hi mate I am having the same problem only pulls the first episode of each disc did you have any luck with it
#3 Post by Woodstock » Fri Nov 01, 2013 7:57 pm
Debug logs, please. See my signature for how to enable them.
kully
#4 Post by kully » Sat Nov 02, 2013 9:36 am
I am running makemkv through vortex box on Linux can you guide me to show what you need
#5 Post by Woodstock » Sun Nov 03, 2013 1:19 am
You're going to have to ask on the support forum for Vortex Box, if the instructions given in the wiki here do not help. Debug logging is generally enabled by using the graphic user interface, under "tools". If Vortex Box hides that from you, then support has to come through them.
Edited to add:
The software utilizes a program called RipIt.
This software automatically rips your CD's in various formats including MP3 and FLAC. It also tags and gathers image art so there is nothing you need to do besides insert the CD.
As of Version 1.6 (with the latest updates) the software also rips your DVDs. It automatically moves the files into your movies folder which then can be accesses with any media device such as a Playstation 3, Roku, Boxee, or any other device that supports DLNA.
According to the Vortex Box website, they're not even using MakeMKV...
