problems with ripping bluray
kully
#1 Post by kully » Wed Oct 30, 2013 2:52 pm
Hi
Not sure if i'm in the right place but I am using vortex box which runs makemkv to rip dvd and blurays to my server.
The problem is a few of the dvd do not rip completely and when ever I insert a blu ray disk nothing happens at all.
Appreciate any help or pointing in the right direction.
Many thanks Kully
Re: problems with ripping bluray
#2 Post by Woodstock » Wed Oct 30, 2013 10:11 pm
What version of MakeMKV are you running? Do you actually HAVE a Bluray drive in the system? You've given very little information to work from.
kully
#3 Post by kully » Thu Oct 31, 2013 8:00 am
Sorry im running MakeMKV v1.8.5 linux(x86-release).
I do have a blu ray player as I managed to rip Die Hard 1 once.
But since then no other blu ray disk are recognised. Also I tried to rip Die hard again and had the same problem with that disk.
Is it possible the blu ray part of the drive is faulty.
Thanks Kully
#4 Post by Woodstock » Thu Oct 31, 2013 10:21 pm
If it is reading DVDs, then the mechanical parts are probably working.
Do you have debug logging enabled? Posting the log from starting MakeMKV up and inserting a BD to be ripped might be helpful.
kully
#5 Post by kully » Sat Nov 02, 2013 9:37 am
Hi thanks for your help bought a new blu ray drive and tried it again all works fine now
