Folder name not showing automatically after changing setting
texmexalex
Post by texmexalex » Sat Oct 12, 2013 8:00 pm
Default saving folder is "E:\Videos" then shows the title after dvd inserted, "E:\Videos\DVDTitle"
After changing the option of the default folder to "E:\Todays Videos" then the title does NOT show after dvd inserted. This bug needs to be fixed if possible.
Re: Folder name not showing automatically after changing set
Post by mike admin » Wed Oct 16, 2013 6:26 am
Change back the setting to "semi auto". You've changed it to "custom".
dwaynnyt
Post by dwaynnyt » Sun Oct 27, 2013 1:21 pm
Hi texmexalex. Where did the "today" come from? Can you recall if you set that up under custom?
