Default saving folder is "E:\Videos" then shows the title after dvd inserted, "E:\Videos\DVDTitle"
After changing the option of the default folder to "E:\Todays Videos" then the title does NOT show after dvd inserted. This bug needs to be fixed if possible.
Folder name not showing automatically after changing setting
texmexalex
Re: Folder name not showing automatically after changing set
Change back the setting to "semi auto". You've changed it to "custom".
dwaynnyt
Hi texmexalex. Where did the "today" come from? Can you recall if you set that up under custom?
