Hi, this is my first visit, there appears to be other similar threads but the debug logs all differ. I've been happily using makemkv for the past few weeks (ripping/converting all of my blu-rays/dvd's to hard disc to play on my wdtv) and now it's suddenly stopped working. Earlier I'd inserted a region 1 DVD which was rejected, but I dismissed the offer to change the region code on the dvd/blu-ray player, then I just keep getting the same error message from makemkv (the title of this thread) regardless of the disc I insert; not sure if teh region 1 thing is a red herring? Below is the output and also the txt log. Hopefully someone out there can help me....please?
MakeMKV v1.8.5 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\John/MakeMKV_log.txt
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
Title #01900.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
DEBUG: Code 233 at 6iJeMKOFiwPR4hQnoBhANUmn:0
Saving 1 titles into directory C:/Users/John/Videos using profile 'WDTV' from file 'C:\Program Files\MakeMKV/wdtv.mmcp.xml'
AV synchronization issues were found in file 'C:/Users/John/Videos/title00.mkv' (title #1)
AV sync issue in stream 0 at 0:02:05.166 : video frame timecode differs by +0.1ms
AV sync issue in stream 0 at 0:02:05.333 : video frame timecode differs by +0.1ms
AV sync issue in stream 0 at 0:02:05.500 : video frame timecode differs by +0.1ms
AV sync issue in stream 0 at 0:02:05.667 : video frame timecode differs by +0.1ms
AV sync issue in stream 0 at 0:02:05.833 : video frame timecode differs by +0.1ms
AV sync issue in stream 0 at 0:02:06 : video frame timecode differs by +0.1ms
AV sync issue in stream 0 at 0:02:06.167 : video frame timecode differs by +0.1ms
AV sync issue in stream 0 at 0:02:06.334 : video frame timecode differs by +0.1ms
AV sync issue in stream 0 at 0:02:06.501 : video frame timecode differs by +0.101ms
AV sync issue in stream 0 at 0:02:06.668 : video frame timecode differs by +0.101ms
AV sync issue in stream 0 at 0:02:06.668 : too many video frames with invalid timecodes, future messages will be suppressed
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 0 to file C:/Users/John/Videos/title00.mkv
0 titles saved, 1 failed
Debug log started at Sun Oct 27 09:25:10 2013 , written by MakeMKV v1.8.5 win(x86-release)
001005:0000 MakeMKV v1.8.5 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\John/MakeMKV_log.txt
003305:0000 AACS directory not present, assuming unencrypted disc
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
003307:0000 File 00000.mpls was added as title #0
003025:0000 Title #01900.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at 6iJeMKOFiwPR4hQnoBhANUmn:0
005015:0000 Saving 1 titles into directory C:/Users/John/Videos using profile 'WDTV' from file 'C:\Program Files\MakeMKV/wdtv.mmcp.xml'
004007:0010 AV synchronization issues were found in file 'C:/Users/John/Videos/title00.mkv' (title #1)
004047:0010 AV sync issue in stream 0 at 0:02:05.166 : video frame timecode differs by +0.1ms
004047:0010 AV sync issue in stream 0 at 0:02:05.333 : video frame timecode differs by +0.1ms
004047:0010 AV sync issue in stream 0 at 0:02:05.500 : video frame timecode differs by +0.1ms
004047:0010 AV sync issue in stream 0 at 0:02:05.667 : video frame timecode differs by +0.1ms
004047:0010 AV sync issue in stream 0 at 0:02:05.833 : video frame timecode differs by +0.1ms
004047:0010 AV sync issue in stream 0 at 0:02:06 : video frame timecode differs by +0.1ms
004047:0010 AV sync issue in stream 0 at 0:02:06.167 : video frame timecode differs by +0.1ms
004047:0010 AV sync issue in stream 0 at 0:02:06.334 : video frame timecode differs by +0.1ms
004047:0010 AV sync issue in stream 0 at 0:02:06.501 : video frame timecode differs by +0.101ms
004047:0010 AV sync issue in stream 0 at 0:02:06.668 : video frame timecode differs by +0.101ms
004047:0010 AV sync issue in stream 0 at 0:02:06.668 : too many video frames with invalid timecodes, future messages will be suppressed
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:0000 Failed to save title 0 to file C:/Users/John/Videos/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sun Oct 27 09:32:10 2013
Re: Copy complete. 0 titles saved, 1 failed
What is the source for the conversion? Looks like an incorrectly mastered blu-ray.
snequers
Hi, my brother backed up my originals to disc some time ago. The reason I posted this log is that the disc had previously been converted by makemkv before the problems started, but now fails along with everything else. Thanks.
