The Internship - Odd error
DJRumpy
Re: The Internship - Odd error
Post by DJRumpy »
I take it simply copying the contents to the hard drive failed as well? If so, it's your drive. You could try cleaning the heads. You can get a head cleaner from various electronics stores.
superx
Post by superx »
I will try copying withe the new disc.
what is weird is now it will not give me any errors just says backup failed.
thanks for your help by the way
superx
Post by superx »
Copied the files and once it gets to 0625.m2ts
says corrupt of invalid trying offset.
Looks like I may need a new blu-ray drive
superx
Post by superx »
Was able to copy it locally but still give errors.
The source file '/BDMV/STREAM/00625.m2ts' is corrupt or invalid at offset 29110272, attempting to work around
The source file '/BDMV/STREAM/00625.m2ts' is corrupt or invalid at offset 29116416, attempting to work around
same issue with all 3 discs.
would this drive be ok to purchase
http://www.canadacomputers.com/product_ ... _id=054293
DJRumpy
Post by DJRumpy »
Well, you've eliminated the ripping software as a possible cause. A couple of things to verify before you buy a new drive.
Some disks also have defects purposely placed into the disc. These 'dummy' tracks are not read by your player, and are there to mess with you as part of some copy-protection schemes. Make sure you are ripping only the main movie. I had only one title showing on mine, but I filter out tracks less than 20 minutes.
Try cleaning the heads. It could just be a bit of dust.
As a last option, if you have the capability, you can try flashing the rom if there is an update available.
superx
Post by superx »
Yes I am only ripping the main movie.
its seems that whenever it gets to the 625.m2ts it starts giving errors.
Very frustrating.
on a side note is this a good drive
LG (WH14NS40)
DJRumpy
Post by DJRumpy »
You might try and find out if the drive has any updates available. I've had a few dives in the past that a flash to the rom would resolve. I'm fortunate in that the BD-Rom I bought is similar to a laptop drive where the heads are exposed when the tray is ejected and easily cleaned (but also prone to getting more dust on them).
crowfax
Post by crowfax »
So far as I'm aware there is no copy protection on blu-ray that messes with file structure which would cause these issues.
If you simply can't copy the files off the disc then the chances are the disc is bad. It's good you've returned it and tried with another disc but the fact that it's failing doesn't really point to the drive yet, bad discs come in batches when they're pressed.
If you can, try it on a friends machine, but statistically speaking the chances are you still just have a bad disc.
superx
Post by superx »
crowfax wrote:So far as I'm aware there is no copy protection on blu-ray that messes with file structure which would cause these issues.
while I agree I find trying 3 discs front different stores, and they all freeze at the same spot.
Just frustrating as I am running out of returns to stores.
superx
Post by superx »
cleaned the disc and cleaned the blu-ray drive.
Now makemkv gives this error in log.
005014:0000 Saving 1 titles into directory H:/Blu-rays
001003:0020 DEBUG: Code 0 at u=I$ueq6w]*U}Re&:29401014
001003:0020 DEBUG: Code 0 at }B+,WFjsADYrKnv'p:29395126
001003:0020 DEBUG: Code 0 at k8MxicX{l`}0?]G0>.b:121263820
001003:0020 DEBUG: Code 0 at 4*{Mph160jt&UF #kHb:213131410
001003:0020 DEBUG: Code 0 at 4*{Mph160jt&UF #kHb:29397564
001003:0020 DEBUG: Code 0 at KwcuwVsI0HV3:)B[:213130122
001003:0020 DEBUG: Code 0 at aQz@ofj}|gB~qlTc:c}Y3:29398369
001003:0020 DEBUG: Code 0 at aQz@ofj}|gB~qlTc:c}Y3:121266925
001003:0020 DEBUG: Code 0 at aQz@ofj}|gB~qlTc:c}Y3:29398645
001003:0020 DEBUG: Code 0 at No`aH1MMy;-:gG!!Ek:213135067
001003:0020 DEBUG: Code 0 at No`aH1MMy;-:gG!!Ek:213135481
005003:0000 Failed to save title 0 to file
DJRumpy
Post by DJRumpy »
Same error on same MTS when copying the files in the OS rather than in MakeMKV after cleaning the drive?
superx
Post by superx »
That error is direct from the disc. trying to do a full backup.
I have tried so many things. The only thing is left is to get a different drive.
DJRumpy
Post by DJRumpy »
Considering it would be your fourth disc replacement if you did so, I would tend to agree. If there were others reporting the same error after the updated SVQ I would suggest you wait but the updated file resolved my issues, and I haven't seen any other posts of the same. You could always ensure whoever you bought it from has a decent return policy.
superx
Post by superx »
Was able to make a encrypted backup iso of the whole disc, mounted it with Virtual Clone drive.
Then got these errors while just trying to load it in makemkv
DEBUG: Code 8 at }a59i:ul%6`jIs(0D+:121262003
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom6'
DEBUG: Code 0 at ~V%IQ(\#2%uj>L6s!:213130743
DEBUG: Code 0 at }a59i:ul%6`jIs(0D+:121262946
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom6'
DEBUG: Code 0 at }a59i:ul%6`jIs(0D+:121263291
Keeps going on after that.
DJRumpy
Post by DJRumpy »
No idea if you can use a virtual drive without any issues. MakeMKV may not play well with that setup. You would ping Mike to see if he's ever tried using it with a virtual drive.
