All worked great.
Great App.
Today, I did a fresh install of Mavericks 10.9 from App Store.
I did a fresh install on daspi 1.3 - it said it installed correctly (though it took a while).
I ran MakeMKV 1.8.5 and it said it was using Open mode (or something like that) and it recommended that I run with DASPI.
I thought I had installed DASPI.
I checked the syslog and found that it was not loaded as there's a problem with it:
Oct 24 20:39:03 dineshs-mac-pro.home com.apple.kextd[12]: kext com.makemkv.kext.daspi 100009000 is in exception list, allowing to load
Oct 24 20:39:03 macnb-mac kernel[0]: kxld[com.makemkv.kext.daspi]: The following symbols are unresolved for this kext:
Oct 24 20:39:03 macnb-mac kernel[0]: kxld[com.makemkv.kext.daspi]: __ZN9IOService19_RESERVEDIOService0Ev
Oct 24 20:39:03 macnb-mac kernel[0]: kxld[com.makemkv.kext.daspi]: __ZN9IOService19_RESERVEDIOService1Ev
Oct 24 20:39:03 macnb-mac kernel[0]: Can't load kext com.makemkv.kext.daspi - link failed.
Oct 24 20:39:03 macnb-mac kernel[0]: Failed to load executable for kext com.makemkv.kext.daspi.
Oct 24 20:39:03 macnb-mac kernel[0]: Kext com.makemkv.kext.daspi failed to load (0xdc008016).
Oct 24 20:39:03 macnb-mac kernel[0]: Failed to load kext com.makemkv.kext.daspi (error 0xdc008016).
Oct 24 20:39:03 macnb-mac.home com.apple.kextd[12]: Failed to load /System/Library/Extensions/daspi.kext - (libkern/kext) link error.I restarted the OS but made no difference - same errors.
I manually tried to load the daspi.kext using kextload - same errors.
Seems like there's incompatibility between daspi.kext and 10.9 ?
