The Internship - Odd error
DJRumpy
Post by DJRumpy »
Processing BD+ code using generic SVQ from builtin/00000.svq
It reported an odd error that doesn't show up in the MakeMKV console. Something about errors encountered, and using the generic SVQ, and then it said that the rip may contain errors. It seemed to complete as expected, but the ripped file has a ton of macro blocking and smearing. I've tried it with a few different players and they all show the same defects.
It did create a 43MB dump file. I can upload it if you like.
superx
Re: The Internship - Odd error
Post by superx »
yes same error. I sent my file but do not know if he got it.
DJRumpy
Post by DJRumpy »
Thanks for confirming. I was expecting the error to show in the log, but it didn't. I wish I had snagged a screenshot of it now.
superx
Post by superx »
Any update on this?
Post by mike admin »
Thank you for sending the dump. SVQ is updated, MakeMKV should download it automatically and everything should work now.
DJRumpy
Post by DJRumpy »
Excellent and thanks. I see that it downloaded a disk specific SVQ.
superx
Post by superx »
Trying to rip this now and exchanged my disc thinking it was a bad disc.
The source file '/BDMV/STREAM/00626.m2ts' is corrupt or invalid at offset 24576, attempting to work around
The source file '/BDMV/STREAM/00626.m2ts' is corrupt or invalid at offset 30720, attempting to work around
The source file '/BDMV/STREAM/00626.m2ts' is corrupt or invalid at offset 73728, attempting to work around
The source file '/BDMV/STREAM/00626.m2ts' is corrupt or invalid at offset 79872, attempting to work around
The source file '/BDMV/STREAM/00626.m2ts' is corrupt or invalid at offset 98304, attempting to work around
The source file '/BDMV/STREAM/00626.m2ts' is corrupt or invalid at offset 116736, attempting to work around
The source file '/BDMV/STREAM/00626.m2ts' is corrupt or invalid at offset 122880, attempting to work around
Same problem from both discs.
finally ripping now though. weird.
DJRumpy
Post by DJRumpy »
FYI, mine ripped without issue with the disk specific SVQ.
superx
Post by superx »
spoke too soon, gave me an error going to try a full disc backups.
getting lots of hash checked errors..
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00626.m2ts' at offset '1137530880'
Backup failed
what does this mean?
superx wrote:Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00626.m2ts' at offset '1137530880'
Backup failed
Bad luck - /faq/item/7/catid/6
superx
Post by superx »
I highly doubt that since this is my second disc from a totally different place.
superx
Post by superx »
This Issue may have to do with Bus Protection.
What is bus protection? Is this the reason I am getting all these errors?
DJRumpy
Post by DJRumpy »
Unlikely. You might try copying the entire contents of the BD to your hard drive and then opening it with make MKV from there ( Command + O ).
That will eliminate your drive and the media as a potential issue.
superx
Post by superx »
will give that a try, thanks for the response.
superx
Post by superx »
Well exchanged the disc at another location, and still will not work. Other discs are working, without any issues.
