bought makemkv and now might have to reinstall linux...
sandbucket
#1 Post by sandbucket » Sat Oct 19, 2013 3:26 pm
Hi i bought a makemkv key and now i might have to reinstall my linux setup, so what do i have to do to keep my key after reinstallation?
crowfax
Re: bought makemkv and now might have to reinstall linux...
#2 Post by crowfax » Sat Oct 19, 2013 3:30 pm
You still have the email from when you purchased, yes?
Once you re-install your system just copy they key from the email back into the registration box inside MakeMKV.
sandbucket
#3 Post by sandbucket » Sat Oct 19, 2013 3:48 pm
kk thanks, will post if i have any problems
dwaynnyt
#4 Post by dwaynnyt » Sun Oct 20, 2013 4:13 pm
You should be good to go if you still have that old email. If not, then probably, you can just ask for a new one. Tat's just based on experience for me.
SorenM
#5 Post by SorenM » Mon Oct 21, 2013 5:01 pm
sandbucket wrote:Hi i bought a makemkv key and now i might have to reinstall my linux setup, so what do i have to do to keep my key after reinstallation?
Personally, I always back up the ~/.MakeMKV folder, and restore that after a reinstall. You don't need the entire folder, but only the *.conf files therein. I am just lazy and backup the entire folder.
