Last king of scottland and new BD+
It looks like MakeMKV generic BD+ svq is disabled in all discs that were released after february 2010. The only known disc so far is a "Last king of scottland". We are analysing the dumps and will post updated SVQ as it will be available.
MrQwtLtn
Re: Last king of scottland and new BD+
my log file printed below.. no go
Debug log started at Thu Feb 04 03:06:20 2010 , written by MakeMKV v1.4.11 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.11 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\sam/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003326:000000:0000 Loaded 1 SVQ file(s)
003334:000000:0000 Processing BD+ code, please be patient - this may take up to few minutes
003332:000000:0000 Processing BD+ code using generic SVQ from allcombo.svq
001012:000000:0020 DEBUG: Code 0 at Tappane}-anFFptW:213133457
001012:000000:0020 DEBUG: Code 0 at Tappane}-anFFptW:121263061
001012:000000:0020 DEBUG: Code 0 at Tappane}-anFFptW:29398415
003333:000000:0000 Failed to process BD+ code using generic SVQ from allcombo.svq
001012:000000:0020 DEBUG: Code 0 at O:4B^/!d\_gUV8"DU+Er@:213133250
003341:000000:0000 Saved BD+ dump file as C:/dump_The_Last_King_of_Scotland_7D395FE1D82AD3E4.tgz
003329:000000:0000 Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
001012:000000:0020 DEBUG: Code 0 at s3T6@\rX=d* 9h:rquK:213132721
005010:000000:0000 Failed to open disc-
swiftfin
does not work
Turned out to be a false alarm. MakeMKV generic key continues to work as expected. If this title doesn't work for you, you know why by yourself already. The end.
