BONES - The Complete Eighth Season
2dogguy
#1 Post by 2dogguy » Mon Oct 14, 2013 12:03 pm
I'm gettin ghtis message when using MKV on Bones season 8
BD+ code processed but no FUTs were obtained, errors may follow
There are errors in the playback of the file - plays fine on my Blu-ray player
Re: BONES - The Complete Eighth Season
#2 Post by Woodstock » Tue Oct 15, 2013 10:29 pm
Accompanying that report is a path to a TGZ file on your system, that should be sent to svq@makemkv.com to be used for generating the fix...
bgpargal
#3 Post by bgpargal » Wed Oct 16, 2013 5:58 pm
I am getting an error message with the blu-ray dvd " The Heat " "BD+ code processed but no FUTs were obtained, errors may follow"
There are errors in the playback of the file. I downloaded MakeMKV version 185, re-registered and got the same results.
2dogguy
#4 Post by 2dogguy » Wed Oct 16, 2013 6:34 pm
Woodstock - The file is too large to email (40+ MB) so I was going to upload it here, but that doesn't work either. The forum refreshes before the upload is done and the posting clears. Thoughts?
#5 Post by Woodstock » Thu Oct 17, 2013 12:07 am
You will need to use a "drop box" service, and send the link to pick up the file to svq@makemkv.com . I'm not that familiar with the free ones, because I run my own web servers.... it's easy to forward big stuff to Mike for me! ;)
One mentioned in another message today is "sendspace.com".
2dogguy
#6 Post by 2dogguy » Thu Oct 17, 2013 1:02 am
Done and done Woodstock - I do have DropBox so that was a good suggestion. Hope its fixable.
#7 Post by mike admin » Thu Oct 17, 2013 7:10 am
SVQ updated for disc 2. We still have no dump for disc 3 (if it exists).
2dogguy
#8 Post by 2dogguy » Thu Oct 17, 2013 11:29 am
Updates for disc 3 - 5 sent
Thanks !
Jon Walker
#9 Post by Jon Walker » Fri Oct 18, 2013 7:01 pm
mike admin wrote: We still have no dump for disc 3 (if it exists).
In case they are needed, have posted an additional set of Bones: Season 8 SVQ dump files. URL to page containing a list of individual Disk dump files sent to the SVQ email address. Update for Disc 2 downloaded to system and, as others have already reported, is working correctly.
2dogguy
#10 Post by 2dogguy » Fri Oct 18, 2013 9:54 pm
I just sent a 2nd email with the DropBox links.
#11 Post by mike admin » Sun Oct 20, 2013 3:49 am
SVQ updated. Once again, thank you all for sending the dumps.
m3zercat
#12 Post by m3zercat » Sun Oct 20, 2013 7:07 pm
I'm having issues with the second (12th in the series) episode from bd disc 3 from the bones series.
MakeMKV fails to copy just the one track from the disc.
In the log window it keeps saying (i copied just one of the many lines because they're all the same except for the offset):
The source file '/BDMV/STREAM/00801.m2ts' is corrupt or invalid at offset 3461216256, attempting to work around
The disc is brand new from amazon. I've checked the disc for blemishes and none are visible to the naked eye when holding it up to a light or otherwise. I've also retried the disc in a different blu-ray drive although same make and model.
Is this still a problem with the physical disc and is that grounds for me to return it to amazon for replacement?
2dogguy
#13 Post by 2dogguy » Mon Oct 21, 2013 4:49 pm
m3zercat - I've had no issues with this set - may not help but maybe a return? Does it play OK in your Blu-Ray player (video player)?
findiavel
#14 Post by findiavel » Wed Oct 30, 2013 7:01 am
m3zercat - I've got similar problems with discs 2 and 3. I found eps 9 , 14 and 15 unreadable. I also found some ring-shaped blemishes with some weird dots on those two discs.
I believe those blemishes are not on plastic surface, they seem to be on reflective surface(s). Look closely with bright light, close to the middle of disc.
My copy is going back to Amazon UK.
